FixYa.com
Samsung LE32R74BDX 32 in. HDTV-Ready LCD Television
All Products > Samsung > Flat Panel Televisions
Problems with Samsung LE32R74BDX 32 in. HDTV-Ready LCD Television?
Troubleshooting and Support
Solved Problems for Samsung LE32R74BDX 32 in. HDTV-Ready LCD Television RSS Feed Post a New Problem
my samsung tv wont turn on, red light...
LE32R74BD this is the model ov tv. Please help
1 Solution
wont turn on
red light  up , but clicking sound is heard
1 Solution
samsung tv LE32R74BD standby light on but...
samsung tv LE32R74BD had tv on standby came back and tv wudnt turn on, standby light flashes when i press a key on the...
9 Solutions
Lost ITV channels and C4
I have suddenly lost all ITV Channels, Channel 4, E4 on my Samsung LCD TV with built in digital freeview. If i plug in a...
1 Solution
samsung le32r74bdx 32
1 Solution
dark vertical lines on tv screen
Dark vertical lines apearing when screen on a white or light backgroung I've tried my manuals troubleshooting section...
7 Solutions
lcd not turning on
I have a 32 inch lexsor lcd tv and its stopped working. when i press the power butten the light goes blue from red then...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Samsung LE32R74BDX 32 in. HDTV-Ready LCD Television RSS Feed Post a New Problem
Samsung LE32R7
Hello, Do you still have the problem with your TV: flashing red light and no sound or picture? Did you find a solution?...
Post a Solution
poor resolution
When I connect computer to Samsung 26 in LCD I have a poor resolution-
Post a Solution
LE32R74BDX 32 standby light flashing but...
LE32R74BDX 32 standby light flashing but wont switch on. have disconnected from power supply and then reconnected no...
Post a Solution
Same problem: LA40R71B
We have the same problem with our 14 month old 42" Samsung LCD. Problem is that TV switched off by itself, then red...
Post a Solution
Green blobs of haze on my LCD on all...
I have large blobs of green haze over certain parts of my picture. They're in different positions as you change tv...
Post a Solution
samsung lcd tv ltm1755b won't turn on...
I have had this tv for 4 years, and recently the power light on the bottom right front of the tv started flashing when...
Post a Solution
Samsung HPS 5073
This less than 18 month old turns it self OFF then ON after about 20 minutes? Hello! Strange thing happening with my...
Post a Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Screen Size32 inch
Contrast Ratio5,000:1
Digital TV StandardHDTV-Ready - Requires separate receiver to view HDTV signals. · HDTV-Ready Television
Flat Panel TypeLCD Television
Display Resolution1366 x 768 pixels
HDCP SupportWith HDCP Support
Display Capabilities
Broadcast Format Supported576p · 576i · 1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Broadcast Format Displayed480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Native Aspect Ratio16:9
Image Quality
Brightness500 cd/mē
Viewing Angle178
Adjustable Color TemperatureWith Adjustable Color Temperature
Remote Control
Remote ControlUniversal
Illuminated RemoteNon-Illuminated
Audio Features
Audio TypeVirtual Surround
MTS StereoSAP / MTS Stereo
Audio LevelerWith Audio Leveler
Technical Features
Picture in PictureWith PIP
Parental ControlProprietary
Sleep TimerWith Sleep Timer
Connectors
Headphone JackWith Headphone Jack
Rear Input ConnectorsComposite x 1 · RF x 1 · DVI x 1 · Audio (RCA) x 2 · 1 x D-Sub (RGB PC) · HDMI x 1 · 21-pin Scart x 2
Front Input ConnectorsComposite x 1 · Audio (RCA) x 1
Rear Output ConnectorsAudio (RCA) x 1 · Optical Digital
Screen Text
OSD LanguagesEnglish · French · German · Italian · Swedish
Channel LabelsWith Channel Labels
Closed Caption on MuteWithout Closed Caption On Mute
Speakers
Number of Speakers2 Speakers
Speaker Power2 x 10 Watt
Dimensions
Depth3.15 in.
Height21.59 in.
Width31.5 in.
Weight34.39 lb.
Samsung Contact Information
Main support number1-800-SAMSUNG
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
