SOURCE: Leaking whirlpool duet washer front load
remove and clean any obstruction or deposits around the inner door seal use H.E. detergent over sudsing can cause that too.
SOURCE: GE front load washer (clothes)
THANK YOU. for those of you with a screw driver, here are the photos on how to.
It takes a philips screw driver and 20 minutes. The white screws may
not align perfectly but don't worry, just get them to go back in the
hole(no harm done).
I'm going to admit it was my wife that found this fix, so now I give the step by step photos.
[IMG]http://i26.tinypic.com/23upff6.jpg[/IMG]
Small white screws (3 in total)
[IMG]http://i30.tinypic.com/69n9eh.jpg[/IMG]
cover "falls" off
[IMG]http://i29.tinypic.com/24erogl.jpg[/IMG]
Unscrew the lint trap (turn to the left)return when clean to hand tight
[IMG]http://i32.tinypic.com/9uralw.jpg[/IMG]
Bob's your uncle and a freebee for CMKX'rs.
Hub and wife team.
SOURCE: Clothes come out extremly wrinkled on top loding whirlpool washer
This is normal. You can try a lower spin setting or smaller loads. The wrinkles will come out in your dryer.
SOURCE: Whirlpool Duet Washer Leaking
For those wondering about replacing the water inlet valve - this is a very simple undertaking. You can find the part online for around 40 bucks. All you have to do is unplug the washer, detach the hot and cold supply hoses, remove the lid (3 torx bits on my model) unhook the water line from the old inlet valve (conveniently accessible at the top right of the unit from the rear), unhook the electrical connections (be sure to label these for later re-attachment), unscrew the 1 screw holding the valve in place, and reverse the process with the new valve. I'm hoping this will stop water accumulating in the drum - I'll update later if it does not.
SOURCE: GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; justanswer.com with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
