The machine works perfectly and the noise goes away on its own.
Have you tried a brand-new needle? Frequently, a bent or damaged needle will make noise.
If you are able, hand turn the handwheel and watch the needle and hook action. You may see the needle hitting. Or try removing the needle and listen if the sound continues. If it doesn't, then it's the needle. If a new needle doesn't cure the problem, could be the needle/hook timing is off. May need service.
