Question about Singer Sewing Machines
I have a singer cxl electronic sewing machine and i have a problem with the needle either not moving or stopping when stitching the larger motifs or the zigzag stitch, somtimes the needle jut moves too far to the right and hits the plate or foot, seems to have a real problem with the side movement. I took it for a service but the technician said he couldnt fix it and he spoke to few other technicians, and they don't really know what to do. Please help.
Posted by a_herta on
  • a_herta Apr 02, 2011
    Yes, but now that there is a problem how do I have this machine problem fixed, if it hits the plate always and the pressor foot is down and no technician is able to fix it, what do i now. Do you have any advice i can give to my technician on how to fix this problem?
Bill Yee
    Sergeant:
  • 236 Answers
The needle either not moving or stopping is a sign that the machine is jamming. Here's the answer for the question "My machine is jammed" from the FAQs on Singer's web site at http://www.singerco.com/support/faqs.html
A jammed machine is caused by thread being caught in the hook. Remove the upper thread and the bobbin case, turn the hand wheel towards you (counterclockwise) by hand and remove any thread in the bobbin case area. *Always turn the hand wheel towards you. Turning the hand wheel away from you (clockwise) can cause the machines timing to become unaligned and jam your machine. Also, always make sure the presser foot is in the down position before you start sewing. Sewing with the presser foot in the up position will jam your machine in the bobbin case.
Your description of the needle hitting the plate or foot is an indication that the machine's timing has become unaligned which can be caused as indicated above by turning the hand wheel away from you - the correct way is to *Always turn the hand wheel towards you.
Posted on Mar 03, 2011
I am trying to replace monofilm panels in a windsurfing sail, using a Singer 457 zig zag sewing machine. I cannot create a good zig zag seam when the monofilm is sandwiched between two canvas layers.
Joe, you might try a larger needle than you're using. You might also want to try a larger leather needle. You machine should take needles up to a size 18.
It sounds like the needle you're using is having a problem picking up the bobbin thread, and that might solve it.
Mar 09, 2017 | Singer Sewing Machines
How can I stop my material sliding around when I am sewing?
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? t
May 16, 2015 | Sewing Machines
Cxl manual
User's Manuals, including yours, are available as a free download the Singer Sewing Machine website. Actually, when you enter CXL you get the XL-50 user's manual, which is essentially the same machine, although a few of the patterns may be different. The CXL, XL-50, XL-10 and XL-1 are basically the same machine; I own a CXL and XL-50, and love them. They can sew SIDEWAYS--straight AND zigzag stitch!
Jun 12, 2014 | Singer Sewing Machines
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
I have a Singer 327K that stitches three or four good stitches and then stops completely stitching
it's very possible that when the needle broke the machine went out of time & would have to be retimed at a sewing machine shop
Mar 10, 2012 | Singer Sewing Machines
Singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Apr 08, 2009 | Singer Quantum XL-1000 Computerized Sewing...
I have a quantum cxl. It will sew normal stiches but it will not sew the decorative stiches
The needle shaft sticks to the curved arm and won't come down because a piece of plastic, about an eighth of an inch thick had broken from age. It prevented the shaft from staying up on the needle arm. Open the cover, try to stitch decorative stitch and see what I mean. Purchase a package of 4-10 by 1/2 nut and bolt pack. Screw the nut all the way onto the bolt. Using needle-nosed plyers, Carefully bend the curved arm slightly, and place bolt into the hole on the top of the needle shaft. Nut will keep it in place. Lowering the needle shaft using wheel, carefully bend arm back in place. Try decorative stitch. It should work. It does for me.
Aug 03, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Sewing Machines Logo
241 people viewed this question
Top Singer Sewing Machines Experts
Chris Wetmore
dannydoesita
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
