20 Most Recent Singer CE-200 Quantum Futura Computerized Sewing Machine Questions & Answers
Yes, from here: Driver Update Software for XP Vista 7 8 Install this software and make the update. Wish you best of luck.
Peter
Singer CE-200... | Answered on Jan 29, 2019
Mine works with Vista. :)
Just install the XP patch (futura-support.com/downloads/patch.htm) and tell Windows 7 to run the software in XP mode.
Singer CE-200... | Answered on May 04, 2018
You probably answered your question. The software is not compatible with the computer.
Singer CE-200... | Answered on Mar 07, 2018
My experience follows: If operating system is Windows Vista go to Singer Futura web site and down load a patch. Make sure you read and get the right one...This worked for me on one computer operating Vista...However, my laptop that is operating on Windows 7 and doesnt have the patch yet...from what I have read it is in the works waiting to be approved by Microsoft - Very Frustrating!
Singer CE-200... | Answered on Feb 10, 2018
Worst case scenario, replace the bobbin winder for $10 on www.sewingpartsonline.com. Not a bad price, or just buy a bobbin winder from JoAnn's or Amazon. I have one and love it.
Singer CE-200... | Answered on Dec 15, 2017
possible that win now extinct win xp cannot handle both as from a compatibility issue
Singer CE-200... | Answered on Nov 17, 2017
I had that problem when the machine was not threaded correctly. I now floss the thread back and forth through the tension area everty time I thread the machine, to make sure the thread is in the right place.
Singer CE-200... | Answered on Nov 16, 2017
Make sure your thread goes under the plate of the carrousel. If not the machine think is not threaded and it beeps. Thread the machine with your left hand and Pull the thread with your other hand to make sure it "clicks" to every part of the machine.
Another important detail is to add thread nets to your spool. After some used the tension of the machine is affected and the nets help the slippery thread to be pulled by the machine correctly and avoiding the beeping.
Singer CE-200... | Answered on Nov 10, 2017
can you help me step by step to get my ce-100 runing thanks
Singer CE-200... | Answered on Oct 26, 2017
"PC" symbols on the machine panel if it is not connected to PC and switched on is a normal behaviour.
As for communication failure try to remember whether something on your pc has been changed: windows upgrade, machine got connected to another usb port etc. If any of such changes have been made try to reinstall Futura software. Otherwise launch troubleshooting utility and send its report to futura-support.
This error means that the arm is not getting the electronic information with the main machine.Make sure the arm is "leveled' with the main machine. I found this out moving gently the arm up or down. I use a piece of thick paper folded in half and put it under one side of the machine (usually the front part of the arm) and then the arm moved showing that the connection was successful. Hope it make sense and helps!
There may be a small "DRIVER" needed for the computer to "see" the sewing machine (*make sure machine is turned on!) when the cable is hooked up. (*could be a bad cable try another they are $2 at fry's) This sometimes requires more computer work to make sure the usb cable is connecting the embroidery machine to the computer correctly.
This driver may be located on your Singer Futura Disk? this is not your program to run the singer machine but the one to connect the two so they can communicate embroidery designs and such.
Deep breaths it will never work if it goes out any window.
Cheers,
Embroidery Services
San Diego, CA
Singer CE-200... | Answered on Sep 20, 2017
I had the same problem, go head with machine off and embroidery unit off also turn wheel toward you. If it still won't go try winding a bobbin that is what happened with mine it seemed to undo the stiffness. You can also take the cap off the wheel and make sure there is no thread wound around it.
Good luck if this does not work there are other tips but it would take all night to email all the steps.
sewsecksy@yahoo.com
Singer CE-200... | Answered on Sep 01, 2017
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
679 questions posted
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Singer Sewing Machines
Most Popular Question
ce 200 quaditron singer sewing machine
  • Sewing Machines
