Manu Palappuram Posted on Apr 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
In my Minolta EP3000, coming white lines while copying
  • Manu Palappuram May 01, 2016
    Thank you for your valuable reply.
    I will try it and inform you soon ...
Kyocera HP Expert
Level 3:
  • Master 532 Answers
  • Posted on May 01, 2016
Kyocera HP Expert
Master
Level 3:
Answers
532
Questions
Helped
287004
Points
1375
If the line comes only when you copying then you need to clean the slit glass. if the line comes with copying and printing you have to clean or replace the drum unit.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Testimonial: "This machine is only Photocopier, Not a printer."
  • Norman Weimar
    Norman Weimar May 01, 2016
    EP series are analog copiers can not print.
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Apr 28, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1914032
Points
11960
Clean the lens and also remove the drum cartridge and clean the drum error and developer section.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3 Related Answers
Anonymous
  • 126 Answers
  • Posted on Jan 24, 2009
SOURCE: minolta ep3000 service m1 ? and how to reset ? can you help
M1= main motor
1. Does the transport motor (M1) operate during power up?
NO, Ensure the connection of the connector (PJ21A) is secure.
2. Replace the transport motor.
YES, Check if there is excessive load on any of the rollers,gears,etc.
3. Replace PWB-A.
Anonymous
  • 109 Answers
  • Posted on Apr 03, 2010
SOURCE: MINOLTA CS PRO EP3000 COPIER. The copy is too dark
try to clean the all mirror
if not
replace the drum
Adorjani Laszlo
  • 1316 Answers
  • Posted on May 22, 2010
Clean the optical parts:mirrors,lens and the charge and transfer/sepaRATOR CORONAS.
Dark copies are coming even I placed a plain white paper as the original in MINOLTA EP3000 Photocopier.
When was the last time the drum and developer where replaced and drum cartridge was clean along with transfer and sep assy??
On display showing problem code 500
Sir,
To clear this code requires you to gain access to the System reset. Open front door locate a small panel with one screw to release it in side will find two small black buttons find service and let machine reset if the code persists then your fusers is gone, the EP3000 is a legacy equipment may find a problem in locating spare parts if the thermistor, thermosat or fuser lamp is shot. Ensure machine is on when you attempt above.
Why are my minolta EP3000 copies very dark all the time?
has the optics been cleaned all the mirrors below the big glass how about the drum and developer has it been replaced?
2answers
My minolta EP3000 CSPRO shows error code coooo
Minolta ep3000 Cspro error code c0000 is plz sloved it
Minolta cs pro EP3000 copier. The copy is too dark even on lightest.thanks
1helpful
Minolta ep3000 service m1 ? and how to reset ? can you help
M1= main motor
3. Replace PWB-A.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
