20 Most Recent Minolta EP1031/1031F CS/PRO Copier Questions & Answers
Main motor remove the fuser unit the hot part check for broken gears also look in the back where the fuser go for bad gear, then check the drum assy. for old cleaning blade if yellow replace it or the drum is stuck use thumbs on the edge of the drum to turn it clockwise looking at the front counter clockwise messes with the cleaning blade. Worse case the motor is dead and or the control board, you try the below web site try for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Minolta... | Answered on Aug 25, 2016
NO, unless you know how to replace the drum and developer.
Minolta... | Answered on Dec 26, 2015
Is the the spanned wrench located on the screen in the lower left? if so touch it the screen will change then open and close the front door the code should go away, if the code comes back need to know what it is,
Minolta... | Answered on Nov 21, 2015
Image unit replace. IF you can find one.
Minolta... | Answered on Nov 14, 2015
Stop 0 Stop 1 gets you in to tech rep mode go to admin settings change your password there.
Minolta... | Answered on Mar 02, 2015
replace the image unit, try the web site below they mite still have them for the ageless old warrior:)
Minolta... | Answered on Feb 22, 2015
NO that is very, very old copier developed before computers where ever thought about connecting to copiers. ITs called and analog copier. NO HARD DRIVE!!!!!!
Minolta... | Answered on Feb 21, 2015
service or operation manual sir/mam?
Minolta... | Answered on Feb 20, 2015
SIR>MAM there is NO hard drive on that machine it is a analog machine it is a very old Minolta Machine!!!! SO NO DRIVES>
Minolta... | Answered on Feb 19, 2015
Could not find that in the service manual But might be the main board. Will it scan if the document is placed on the big glass instead of the document feeder.
Minolta... | Answered on Jan 30, 2015
Toner cartridge and J3 are two different things J3 is jam code something is not correct in the paper path.
Minolta... | Answered on Jan 22, 2015
Power off the machine hold down the stop button and turn on the machine that will reset the machine if it comes back the fusing unit needs to have either the upper fuser roller replaced or the thermistor need to be replaced or the power board needs replacing DO NOT CONTINUE TO RESET it can catch on fire that would ruin a perfectly good day!
Minolta... | Answered on Jan 21, 2015
Pull out the image unit. have the drum removed check the cleaning blade is it yellow replace it. IF you can fine run ! Clean the drum off be careful no liquids USE a clean brush. NO vacuum cleaner the static electricity from the vacuum cleaner can destroy the Developer sensor (Unless you know how to do it). Remove the Transfer assy. located below the drum (Push down and out From the rear also) clean also
Minolta... | Answered on Jan 19, 2015
Do they move across the page as differtent copies come out?
Minolta... | Answered on Jul 04, 2014
Check the image unit. And check the charge grid on the top of the drum. also check the three little springs that the top of the machine comes down on under the image unit.
It is not hard to do... The question is are you a service tech or just want to do it your self. If you are not a tech, it is best to leave it to someone who knows how to do it. It can & will get ugly fast if your not sure on how to do it......
Minolta... | Answered on Dec 24, 2013
Remove the imaging unit ,remove the charge corona assy,remove the OPC drum,remove 2 screw and dump the developer out.Reinstall the imaging unit ,pull out the toner cartridge and push in toner cartride ocation the developer cartridge.Turn on the copier and wait then the copier perform the new developer initialization.Whwn the Start button in ready(green light),change the developer cartridge to toner cartridge.
Minolta... | Answered on Mar 07, 2013
Do the lines show up when you make copies with the adf and the copyboard glass?If it shows up on both you may need a new OPC drum & cleaning blade.
Minolta... | Answered on Sep 05, 2011
Minolta EP1052 - Operates but nothing prints on the paper. Toner seems OK. Can't get to print in any of the exposures.
Any ideas - or has it finally died??
Minolta... | Answered on Mar 30, 2011
58 questions posted
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Inky Fingers
Inky Fingers
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Minolta Office Equipment & Supplies
Most Popular Question
try print gives me blinking j
  • Office Equipment & Supplies
