Hi my ps3's hard drive keeps saying it is corrupted and when I restore it it starts and saying the system is corrupted and restore system but it is like go around in a circle can you please help as it is...
Hi there..
Please follow these steps to get your console out of the HDD corrupt mode.
NOTE THAT BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADD-ONS YOU BOUGHT FROM THE PSN.-
1.Put your PS3 in Standby Mode.
2.you should know your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX-
3.For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
4.For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back in.
5.Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
6.Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
7.Connect controller to PS3,then you will see a screen that says "Connect the controller with the USB cable, then press the PS button"
8.Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
9.you will see a list of options on your screen, select option 5 (Restore PS3 System). Then select yes to perform step.You will then see a screen that says, "The hard disk's file system is corrupt and will be restored."
10.The PS3 will then restart. You will see many different languages, all that it is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
