Just hooked up water line but the water is not coming out , I've held the water dispenser for over two minutes and it won't come out. The fridge is missing the filter, is that the issue?
I am wondering about the hose you shoved in and the leak stopped. Is the hose you pushed in buckled where it hooks on or is there a buckled spot where the water comes out of the fridge. Just a guess.
Where you hook the house water line is to the water inlet valve which is a one in two out solonoid controlled valve. One side goes to the water dispenser in the door and the other hooks to the ice maker connection.
So I suspect the long water line you are talking about has had the lines switched at the valve and needs reversed. The long line probably goes up the back of the unit and connects to the ice maker. The one for the water dispenser should hook to the water chiller resevoir and then to the water dispenser.
Yes there is a way to disconnect the water line. Pull the Fridge out from the wall. The electrical power chord should be on the back side as well as the 1/4" water line. You need to locate a valve and shut off the supply water. Then you can disconnect the line with wrenches. It is located near the bottom.
I have a gsl25jfpe bs ge regrigerator and the baffle motor that controls air flow from the freezer to the refrigerator is out. This had been causing everthing in the fridge to freeze and cause the water to stop working due to water freezing in the storage tank. The baffle is in the back top of the fridge covered with a plastic cover. Remove plastic cover to check baffle function.
