20 Most Recent
Kenmore Side by Side Refrigerator Questions & Answers
Top Shelf of Refrigerator is not cooling, rest of refrigerator is cold
You need to remember, heat rises. If something is out of whack in your refrigerator and it's not able to remove heat properly, the heat it can't remove will rise to the top. I'll list a few things to look at.
1. Do you have ice build up that you can see on the back panel inside your refrigerator? If you do, you'll need to check your defrost cycle and circulation fan.
2. Check the fan by putting your hand by the upper holes on your back panel in the refrigerator. This can be problematic because depending on the age of the refrigerator, the fan might turn off when you open the doors.
3. Check the door seal for breaks, tears, or any leaks. Phycometric laws dictate that warm transfers to cold. So if you have any gap In the seal, warm air will migrate to cold air.
One definitive way to check if it is a defrost issue is to take everything out that might spoil and put in ice chests, unplug the unit, and open the doors for 8 hours to let any ice melt. Plug it back in and if it works properly, you have a defrost issue
Kenmore icemaker tray leaking water (model 795.51022.012)
Do the old 'KISS" thing first (keep it simple ......thing). Chances are that there are tiny calcium deposits in the ice tray which makes an ice cube stick in the tray. If one ice cube sticks, the water will overflow as it needs all the trays empty for the filling. The water will drip down into the freezer area causing chunky ice and stalagmites. The calcium deposits are very teeny in size but will hang up an ice cube from dropping. If more than one ice cube (basically all the ice cubes) didn't drop then the heater in that unit that initially gets the ice cubes to drop could be bad.
I've taken the ice cube assembly out and used vinegar with baking soda to dissolve the calcium and that worked. I left it in for a couple of days. "Do NOT" use anything like a knife or whatever to scrape the bottom of the tray as it will destroy the finish and keep the ice cubes sticking.
When I had the warranty service come out, the technician explained what happened to the tray (calcium). He replaced the tray but the next time it happened I used the vinegar and baking soda. I eventually bought a new tray for 1/2 the price on the internet when the problem happened later on in life.
Only 83 volts to icemaker
yes , when you measure in series with a load in an electrical circuit , you will measure the voltage loss the device causes by exerting its load on the supply power , this is what I suspect your seeing , if the optical sensor looks ok on the bucket thing , I suspect your having the old whirlpool water inlet solenoid problem , id ck that
try adding a small amount of water to ice form tray , if it makes ice in 24 hrs then yep you need a solenoid , also those tiny little sensors they use to sense where ice level is at , can be seen with the use of a simple home video camera (not your phone) , seems home vid cams are extra sensitive too IR light so you can view the light source with it to check it !!
Kenmore Coldspot Model 51572200 is leaking water all over the floor
On the bottom rear of the refrigerator as you are looking at it from behind the left side where the water is feeding into there should be a double valve. 1 is for the water and the other to the icemaker. Many times that valve won't shut off, however the switch that dispenses the water is evidentially bad and needs to be checked if it is stuck open.
