Loosen the screws of the tension unit to clean out some thread and dust/lint, and a spring fall out... have no idea where the spring should be ... any kind soul out there to help very much appreciated.. can't afford service cost. Thanks!
Thank you for your response... yes, I do have a manual. I need a tension unit assembly diagram, and can't seems to find one.Thank you for your response... yes, I do have a manual. I need a tension unit assembly diagram, and can't seems to find one.
You can't post conmments that contain an email address.
Testimonial: "Thank you for helping out..Yes, I do have a manual, but I need a repair diagram (?tension unit assembly) so that I could figure out where the tiny spring goes."
Upper Thread Tension knob on machine is too tight.or needs cleaning to remove lint. Once the needle has been threaded, you should be able to pull thread through the needle with only a modest effort and no breaking.
There is also an adjustment for the lower bobbin (spool) on the spool carrier. for most machines.
The thread coming out from the spool passes under a flat spring to give it tension for an even stitch- to tight it breaks the thread, too loose it leaves you with excess thread per stitch.
If you can remove carrier with bobin, let out about 1 or 2 handspans of thread, and hold the carrier up by the thread. If it falls, it is too loose. If it does not move, not even with a gentle shake- it is too tight. Correct tension will hold the carrier and spool by their weight, and a light shake will have the assembly slow fall as it unstrings the bobbin. The flat spring is held in place by a small screw, just loosen the screw slighlty to allow you to slide the spring one way or the other and retitghten.
A sewing machine operator can often help themselves when their machine does not operate properly. Here are some simple instructions, which if properly used can save time and mechanics service calls. TROUBLE;UPPER THREAD KEEPS BREAKING; This could be trouble;================Do this; 1.Top tension to tight================loosen tension 1 turn 2.Machine improperly threaded=========check threading 3.Thread twisted on guide post========" 4.Thread twisted out of tension=======" 5.Take up spring bent or broken=======Check action of spring 6.Thread jumped off pull off finger===Check threading 7.Needle bent or burred===============new needle 8.Bad cone of thread==================try another cone TROUBLE;LOWER THREAD KEEPS BREAKING; 1.Bobbin tensionspring to tight=======Loosen tension slightly 2.Bobbin threaded wrong===============check threading 3.Bobbin wound to tight or uneven=====try new bobbin 4.lint or thread on bobbin case=======clean inside case 5.Lint or thread inside hook==========clean inside hook 6.Bobbin case nicked bent or burred===check/change case TROUBLE;MACHINE STARTED SKIPPING STITCHES; 1.Needle bent or burred===============change 2.Needle set in crooked===============Check 3.Thread jumped off take up spring====check threading 4.Thread jumped off pull off finger===check threading TROUBLE STITCHES SHOWING LOOPS; 1.Forming loops on top of cloth=======Tighten bobbin tension ======================================or loosen top tension. 2.forming loops on bottom of cloth====Tighten top tension 3.Bobbin placed in case incorrectly===remove and replace 4.Bobbin thread slipped from under====check threading of tension===============================bobbin case 5.Lint or thread in top tension=======clean between tension discs
Its a Kenmore 385-12681
