20 Most Recent Janome D'cor Excel Pro 5124 Mechanical Sewing Machine Questions & Answers
Visit this link for download janome.com/File/ManualFile/5124 En pdf
Hope helps.
Janome D'cor... | Answered on Aug 20, 2018
Did you happen to find this user manual? I have been looking for one as well.
Janome D'cor... | Answered on Aug 05, 2018
i have a manual for this machine. i can make a copy for you if you are willing to pay for paper and postage. it would be less than $10. i know that it is out of print and had trouble myself when i could not find it. peggy pott4@wyan.org.
Janome D'cor... | Answered on May 22, 2017
Hopefully you saved a copy of the file on your computer before loading it on your machine.
Janome D'cor... | Answered on Feb 24, 2016
im loking for u hi and low
Janome D'cor... | Answered on Dec 28, 2015
Suggest you start from the beginning of your manual and totally rethread you machine. Sometimes the beeping means that something is not properly set to sew, ie the bobbinwinder is activated, the presser foot is up, threaded improperly, etc...
Janome D'cor... | Answered on Nov 05, 2015
Incorrect polarity at the plug, or the drive belt is crossed into a figure 8 so it is running the wrong way.
You can also try pushing the knob the right way as you depress the pedal.
Janome D'cor... | Answered on Sep 16, 2015
The button is a relay switch and is an electronic component
Quite easy to replace, but you need to get parts from Janome Authorised Dealer
Janome D'cor... | Answered on Jul 06, 2015
try these sites
sew usa
sewing manuals.com
ebay
Janome D'cor... | Answered on Mar 27, 2015
In English it is here
Janome D'cor... | Answered on Dec 30, 2014
you should be able too, I sent you a link for a manual, the information should be in it.
Janome D'cor... | Answered on Jul 28, 2014
here is a link for a manual, the information should be in it about the twin needles Instruction Manual Janome 5124
This specific model, and most of the Singer Touch and Sew series of machines has several plastic gears that drive either or both the hook, and the feed dogs. Due to age and general wear, these gears eventually break. It is almost 100% likely that one of your gears is broken. It is recommended that you replace all of the plastic gears in your machine at the same time. If you just replace the one broken gear, you are merely shifting the weakest point in the system to another gear, which will also break shortly. If you replace all the gears at once, they will be of equal age and strength. It is best to get this done at a reputable sewing machine repair shop, as this repair involves a complete re-timing of the machine, and can be quite difficult for the novice.
Janome D'cor... | Answered on May 14, 2014
did you ever get a answer to the question you asked?
Janome D'cor... | Answered on May 12, 2014
did you ever get a answer to your questions you asked?
Janome D'cor Excel Pro 5124 Mechanical Sewing Machine Logo
124 questions posted
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Janome Sewing Machines
Most Popular Question
sews in reverse forward when reverse
  • Sewing Machines
