I have two mtx 12inch subwoofers with 500 watt peak and 250 rms rating bridged to the amp
SOURCE: I have two 1200 watt sony amps bridged red light on in one why?
If you are certain speaker isnt blown and you have correct phase wiring and so forth you have whats called a solder jump which is internal repair by dealer only! buy a new amp at dealer wholesale price here cheaper than having it repaired unless under warranty go here for wholesale pricing on almost everything audio wise:
www.godspeedaudioheaven.com
SOURCE: I Have a Sony Xplod 800 watt amp and 2 12 inch Sony Xplod subs
You should definately bridge them. Firstly, lay the 2 speakers face down next to each other. Note the connections +- +-. The first + will go to the amplifier. The next terminal(-) will be connected to the next speaker(+). Take the last(-) and connect to amplifier. Please note that your amplifier has a bridge section which is normally the first + and the last- on the two channels. Connect your woofers on the bridge.
SOURCE: I just bought an '02 Honda Civic SI hatchback that
you have to understand impedance to do this. how many ohm are your 12,s`? you can run all 4 subs in mono off one amp if wired right. it works like this, lets say all 4 of your speakers are 4 ohms. if you wire 2 4 ohm speakers in a series it looks like one 8 ohm speaker to the amp. if you wire them in parallel the amp sees it as 2 ohms, ps most amps cant handle less than 2 ohms in sereo 4 in mono bridge. so no if you take one pair say the tens run them in series now take the 12 run them in series. now take and parallel both sets to amp and you have a 4 ohm load. to better understand do a google search for series parallel circuits. also you amp should be marked for bridging if not look up the amp on the manufacturers web site most will let you download the owners manual for free if in doubt about your amps ability keep it at or above 4 ohms
