Auger will not turn, not sure if it is the auger or temp switch.
SOURCE: purchased a used earth stove mp240 pellet stove
The auger motor is fed through a high temp. limit thermostat. It has a
manual reset on the back of it that you have to press on firmly to
reset it. Open the side panel on the stove and find the wiring. You
will see the thermostat on the back side of the combustion chamber.
Look very closely and reset it.
good luck!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: AUGER IN PELLET STOVE NOT CONSISTANTLY TURNING
The auger motor is fed through a high temp limit thermostat. It has to be manually reset if it activates but it could be causing your problem with a bad connection or intermittently bad. It deserves a look...
SOURCE: auger on pellet stove doesn't turn
The thermostat inside on the back of the combustion chamber has a manual rest that needs to be pushed and reset.
If you have the pellet box too full this will cause the auger to jam.
