20 Most Recent Intex 10x30" Metal Frame Pool w GFCI Questions & Answers
Unplug the unit. The E90 code on the intex spa is due to a dirty water flow sensor. Remove the control panel and all the screw holding the casing on. In the white plastic piece on the discharge, top hose, you will see a silver nut with a black wire coming from it. That's the sensor. The black wire is plugged into a white wire, carefully unplug it and unscrew the sensor. Clean it good and blow out the hole it goes in. This will fix the code and you will be back in business!
Intex 10x30"... | Answered on Dec 11, 2017
Is your filter clean? Is there hair in the impeller? Can you reach in behind the basket to see about the hair in the impeller? If there is hair there, remnove it.
Intex 10x30"... | Answered on Aug 29, 2010
E96 - On what?
Need more info.
Intex Pool & Spa | Answered on Dec 31, 2017
check recirculation pump and heater
Intex Pool & Spa | Answered on Nov 21, 2017
recirculation pump or heater element or temp sensor
Intex Pool & Spa | Answered on Nov 12, 2017
check recirculation pump if ok heating element and temp sensor
Intex 10x30" Metal Frame Pool w GFCI Logo
4 questions posted
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Intex Pool & Spa
  • Intex Pool & Spa
Most Popular Question
no water flow e90 fault code intex pure
  • Pool & Spa
