Televison & Video Logo
G
Greg Posted on Jan 19, 2015
My Phillips TV (42PFL7422D/37)light comes on to show power but the screen does not light up. It does have sound. Guy on line stated it most likely is the T-con board/LCD controller. That this is common on Phillips TV. Does this sound accurate
Its Me Charlie
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Jan 20, 2015
Its Me Charlie
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
3649
Points
35
Try to to put-off your lights and see if you have slight illumination on the screen, if it does, its the t-con board. If totally none, you have to change your Inverter board.
Testimonial: "This was helpful. The screen is dark. Should I replace the Master Inverter, Slave Inverter or both?"
  • Its Me Charlie
    Its Me Charlie Jan 21, 2015
    If you will ask me its better to change both Master and Slave for sure and if the price is not much.
5 Related Answers
olayoju victor
  • 191 Answers
  • Posted on Oct 05, 2008
SOURCE: sound no picture, which component is tcon board? where all audio/video/cable/hdmi plug in to?
for bn94-00963b go and change your backlight inverter
Abcd
  • 70 Answers
  • Posted on Jul 07, 2009
SOURCE: Philips Magnavox 37" LCD Flat
Disconnect the LVDS Cable that runs from the small signal board to the display panel and apply power,if the screen comes on,the Small signal board (aka Scaler Bd ) is the faulty board. other than that,all that's really left that has gone bad for me is the logic board.
Elias Pedraza
  • 53 Answers
  • Posted on Aug 19, 2009
SOURCE: i have a phillips 42 inch lcd model 42pfl7422d
Hello Mendez the problem that your tv set is having is coming from the inverter board this board provides the high voltage for your backlight without the backlight no picture, what i want you to do is go online sometimes this happens go online look for the service manual for your tv set once you find it get it look for the inverter boards location and check the fuse that is on that board sometimes they blow and it will give you this problem if that is your problem you save money and the hassel of taking it anywhere to get it fixed,if it is not the fuse then the inverter board needs to be changed out and that will fix your problem thank you hope this helps.
Anonymous
  • 4 Answers
  • Posted on Aug 30, 2009
SOURCE: Vizio VW42LHDTV10A lcd. Has vertical lines and siren like noise !
Vizio tech says main board.
Chi Chu
  • 8457 Answers
  • Posted on Dec 17, 2009
SOURCE: has sound but no picture
Replaced the LCD inverter board,to get picture back.
1helpful
My phillips 42pfl7422D/37 has Solarization pl help!TV set was use with playstation game console!
Other than replacing the panel there Not an easy fix for solarizarion/ ghosting
Phillips TV Model 42PFL7422D/37 that has audio but no video.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=repair%20led%20tv%20screen
2helpful
2answers
Philips 42PFL7422D/37 42-Inch 1080p LCD HDTV Picture went out but still have sound. Any tips on how to fix it?
If the backlight of the LCD-panel does not function, (no picture) then Master and/or Slave inverter are defective. Inverter boards are screwed to both sides of the LCD display, if they have revision 1.2 boards then they will need replaced with revision 1.3 boards.
Lose sound on phillips hdtv unless xbox360 is turned on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
