If any battery operated watch starts losing time or displaying the incorrect time, this is usually indicative of a battery going bad and needing replacement. My Luminox 3100 started lagging in time and I noticed that the second hand would intermittently stop. I also have a Suunto Vector (Digital) wrist-top computer and the times along with the compass, altimeter, light and alarms all started to act crazy and all it happened to be was the battery being run down. Coincidentally the Suunto has a battery gage that only appears and flashes during low battery charge.
BL: Try the simplest thing first, change your battery. Please be very careful not to break the O-ring on any watch that's waterproof/resistant as this will render the protection useless. Also if your watch is still under a manufacturer or vendor's additional warranty, get them to change it as not to void your warranty. 'Hope this helps!
Synchronizing Wii Remote: Press the power button to turn on your Wii console. Remove the battery cover on the back of the remote . Change the two AA batteries. Open the door on the front of the Wii console and press the RED (SYNC) button at the same time push the RED (SYNC) button in the battery area of the remote. Thats all now have fun.
As jimmyguru said. 1. Pull the crown to the second position (all the way out) 2. Push and hold the reset button and allow the chronograph hand to rotate near the 12 o'clock position. 3. Release the reset button. 4. Repeatedly push and release the reset button to find tune the hand position until it is right at 12 o'clock. 5. Push the crown back in.
Hey there...All you have to do is press the CD MODE button while you press the on/off button and it will fix it. This happened to me as well and I thought that I was going crazy...I changed the 9 volt battery but finally got it to work.
I am not acquainted with the 45CL-1, but as a general rule, if the contacts for one side of a battery is a spring and the other end a solid piece of metal, the negative (-) end of the cell should contact the spring and the post (+) end of the cell should go to the solid metal contact.
I had this problem too, I was going crazy and worried about it, your iDog AMP'D Just needs new batteries, to change it, unscrew the metal screws that are located under it's back legs, and replace the old batteries with three new AA ones. Make sure they are good batteries!
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system) 2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged 3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read) 4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
i have used Digipower AA rechargable and Everready AA rechargable batteries without a problem lasting a long time in this model.
you may have a problem with the battery charger itself.
batteries i am using are rated at 2400-2500 ma
in the menu button, select shooting menu - set up - scroll all the way down to battery type, select the battery type you are using and press ok in the center of the button.
you can use the coolpix nimh selection for other rechargable brands.
