Question about Seiko SNA553 Alarm Chronograph
I have a seiko chronograph sports 150 watch; had the battery changed a few day ago and just noticed that the second hand & stopwatch hands are not 'centered'. is ther a way to reset this ? cheers
Posted by simpson_alan on
Anonymous
As jimmyguru said.
1. Pull the crown to the second position (all the way out)
2. Push and hold the reset button and allow the chronograph hand to rotate near the 12 o'clock position.
3. Release the reset button.
4. Repeatedly push and release the reset button to find tune the hand position until it is right at 12 o'clock.
5. Push the crown back in.
Posted on Jul 05, 2010
  • raybeamer Oct 01, 2010
    I had to repeatedly short the contact and the battery inside the watch first to get the top hand, 1/10, to zero, then follow the above instructions.
  • awtjr1943 Jun 28, 2011
    On some models pull the stem only out to the first position.
Anonymous
    New Friend:
  • 122 Answers
TRY TO DOWNLOAD THE MANUAL FROM A SUPPORT SEIKO SITE.YOUR CALIBER IS 7T62.YOU MUST PULL OUT THE CROWN TO THE SECOND POSITION AND RESET THE CHRONO WITH THE TWO BUTTONS.
Posted on Jun 06, 2010
Anonymous
Pull the stem all the way out (two clicks). Press the upper button to change the zero-position of the stopwatch's second hand; press the lower button to change the zero-position of the minute hand. Reset the time by turning the stem. Push the stem back in. I hope this is clear!
(I couldn't figure this out until I read the replies by jimmyguru and aa member. Thank you both. I am adding the info info that each button sets a different hand of the stopwatch. Hold button in, to move the hand quickly; push it in briefly, to move the hand slowly.)
Posted on Jul 20, 2010
My watch has had the battery changed and when you reset the stopwatch, the second hand and the small hour/minute hands no longer rests on 12. How do I reset these hands
I have the same problem with my Seiko Coutura Chronograph. Ever since battery was changed, the stopwatch resets to 32' 8" instead of 0'0". How to re-zero the hands?
May 08, 2010 | Watches
Bulova 96R31 keeps time + date, but the chronograph does not work
The problem is in chronograph module or related gear train. To find what exactly the problem is, special tools and equipment is needed as well as watchmakers knowledge and skill. There may be just an underpowered battery, but according to your explanation, I tend to think that the first causes mentioned by me are the right ones. Visit your nearest watch repair shop and ask to check your watch for any faults. Rate me, please.
Feb 25, 2010 | Bulova Diamond Chronograph #96R31 Watch...
Stop watch will not reset to zero
pull the crown full out reset all hands set time set alarm or second time if you wish and press the crown back.
Dec 01, 2009 | Seiko Coutura Chronograph Watch
Seiko Chronograph Sport 150 - Problem: After Battery replacement and pressure test (15-Bar), watch hands are not in the correct place. Can this be fixed so the chronograph timing features, and month &...
Please folow this link:
http://www.seiko.co.uk/support/instructionbooklets
Enter your calibre code (its on the back of your watch, it will explain which numbers to you on the website), you'll then be able to download an instruction manual for your watch, this will detail how to adjust hands to their corect starting position :)
Nov 20, 2009 | Seiko SNA553 Alarm Chronograph
Seiko Chronograph 7T32 minute hand inactive after battery replace
you often need to do a full reset on 7T32s (& other seikos) after a battery change. there is a small reset contact in the rear of the movement which needs to be shorted to the top of the battery (the movement is engraved with wording to this effect, something like "AC reset", I can't remember exactly). you might also try pulling out the crown all the way (2 clicks) then holding both upper pushers in for a few seconds. it's unlikely to be a buggered motor unless it's one of the subdials that's failed.
hth-
duncan.
Feb 20, 2009 | Seiko Le Grand Sport SDWF73 Wrist Watch
Minute Hand on Stopwatch Will Not Return to Zero
Here is the link where you can download manual for your watch:
http://www.seikousa.com/pdf/SNA_Series.pdf
The last chapter explains how to reset hands to zero.
Do not forget to rate, please.
Jan 22, 2009 | Seiko Le Grand Sport SDWF73 Wrist Watch
Second hand doesent return to 1200 position after replace batt
I just replaced the battery in my 20yr old Seiko chrono sports 100. And I had the same problem. I think I stopped it on 12 while in stopwatch mode and held down the start stop button and the set button at the same time. See if that works dude.
Dec 06, 2008 | Seiko Le Grand Sport SDWF73 Wrist Watch
Re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. [email protected]
May 18, 2008 | Seiko SNA553 Alarm Chronograph
I have a seiko flight watch, unknown of the model, second hand doesn't reset
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
Apr 27, 2008 | Seiko 0512039FA Wrist Watch
Seiko chronograph alarm
Solution #3 (Posted by Guest on 5 Mar 08) is spot on. Quick and easy method to reset the chrono hands (it was not in my Seiko manual).
Interestingly, this can also be used to set the chrono ahead (or behind--with a little math) for offset timing measurements.
Jan 13, 2008 | Seiko SNA553 Alarm Chronograph
Seiko SNA553 Alarm Chronograph Logo
2,654 people viewed this question
Top Seiko Watches Experts
Marvin
Marvin
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
