54cm
There seems to be an incompatibility between the TV's setting and the antenna's input.
The TV doesn't see the antenna connection and keeps searching.
Somehow you have to get the TV's 'cable' setting in the menu to 'over the air'.
Is there a clean signal coming to the TV? Sometimes a cable can be compromised where the signal never reaches the input connection. Check both ends or at least replace the cable temporarily.
Last but not least, the TV maybe set to a PIP (secondary tuner with a picture in a picture) and the tuner is not electronically connected.
SOURCE: Audio missing on some stations
Solution in audio settings, choose MTS stereo. TV was set to something else.
SOURCE: Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
SOURCE: TV remote dilemna
sempre fi if you are a marine. in all my years of working on every brand of tv, you cannot use a universal remote on a tristar it has to be the factory remote. alot of sets are this way. good luck over there and keep your lid on at all times..come back home in 1 piece. goodday..
SOURCE: Can't get channels above 63 without tuner on cable
i got the same problem to. when i autoprogram it still doesnt do anything. cannot get channels lower than 51 like all the rest of the tvs in my house can. Somebody tell me what to do..
Lets you search for a code for a specific Brand within
the Code Library for a particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the SETUP button until the red
indicator remains on, then release SETUP button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press and release the numeric button (0-9)
corresponding to desired Manufacturer (see table on
code list sheet). The red indicator blinks off once.
Note, pressing "0" performs a full library search same
as normal Code Search Method on previous page.
5. Press the CHANNEL UP button ((or POWER or
PLAY (VCR only)) repeatedly until the device to be
controlled changes channel. The red indicator blinks
off with each button press. If you accidentally
overshoot the code required, press the CHANNEL
DOWN button to backtrack through the library until
the device changes channel. Pressing CHANNEL
UP changes direction to forward again.
6. Press and release MUTE to install the code.
Brand Search Method entry is now complete.
Note: When all codes under a Brand have been searched
the red indicator flashes rapidly for 3 seconds.
Try this. Good luck.
0002 0502 0006 0115
0506 0706 0520 0906 0316
0505 0614 0324 0924 0626
0826 0027 0327 0128 0228
0632 0134 0247 0605 0705 0805
0703 0903 0004 0519 0106 0104
0304 0604 0804 0005 0105 0305
Be patient and check with these codes one by one, till you find the code for your Emerson model.
NB: Switch OFF and switch ON your TV set, with its front panel power control switch, before trying an other code.
Proceedings
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Code Search (by Brand)
Brand within the Code Library for a
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
3. Press and release the desired Mode
(0-9) corresponding to desired
Manufacturer (see table below).
library search same as Device Library
Code Search Method.
POWER or PLAY (VCR only))
the code.
OK.
OK.
