I hit a button on my universal remote and it removed all my programmed channels. I have no idea which button i pushed as it was an accident.
Do a reset to this TV. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: need to find manual for remot
I tryed to look this up for you and I did find the remote on the web site but when I tryed to view the documentation on the remote a note came up and said that there was no on-line documetation for this remote, but I could contact Phililps for it at: 1-888-PHILIPS (1-888-744-5477) Good Luck
SOURCE: Universal code for JVC-AV 27230
please try this web site you will get the solution good luck.
SOURCE: remote
pawnbrokers carry tv's just like yours for under 50 bucks, i'd go that method.........
SOURCE: Lost sponge bob tv remote control
Get the RCA 4 device universal remote from radio shack. model #RCR4383N $10.00. It wouldn't work using the emerson codes in the manual. Let it find the code automatically. input button on bottom will switch to and from AV input.
