SOURCE: Hotpoint Aquarius 1200 WD62 (Tumble drying issue).
no the steam from the dryer part comes out of outlet tube the same tube were the water comes out hotpoint washer/dryers use a condensing chamber which allows the steam to cool down a pass through it as water does and through the outlet pipe
SOURCE: Drying problem
poss a blocked filter or intermittant pump fault or your water valve that supplies your condenser
SOURCE: my aquairius hotpoint washer dryer wd62 keeps tripping electric why
Remove top cover, and unplug motor, try it, and if it does not trip, then motor is causing prob.
If it still trips, then heater is probably causing problem.
Please rate my advice.
Thanks.
SOURCE: loud noise when spin drying
Remove rear panel of washer, and remove drive belt.
Spin the drum by hand, and if it feels rough, or is noisy, then the main drum bearings have failed, quite a big job to do.
Please rate my solution.
Thanks.
