No instruction came with it
SOURCE: carpet shampooer
I couldn't find the exact guide for your model but the two links below are the ones bissell told me to use. http://www.bissell.com/images/UserGuides/1694-8806_607.pdf http://www.bissell.com/images/UserGuides/1697_1205.pdf I hope this helps:)
SOURCE: nothing comes out of my bissell 12amps shampooer
hey here is a trouble shooting guide that has easy steps to walk you through fixing the problem.
http://newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Troubleshooting_ProHeat2X_9400F.pdf
SOURCE: Bissell Pro heat stopped working
It sounds to me like you may have a bad brush and/or pump belt. Since you are having a simultaneous problem of the brushes not spinning, as well as the solution not spraying, this is the most logical explanation of your problem. Especially if the machine was being used on stairs, this could pop the belt off if the brushes were continuing to be run.
This will be the easiest repair on the machine, and hopefully this will take care of it. If it doesn't, there are a handful of other things that it could be, but let's hope that it's simple and just the belt(s).
What you'll want to do is open up the machine to inspect the belts and make sure that both are in place, and not off the machine.
Here's a link to a helpful video that will show you exactly how to open up the machine to check and make sure that the belt is installed.
MAKE SURE THE VACUUM IS UNPLUGGED.
http://www.bissell.com/VideoRating.aspx?id=1555
Please try this first, and if this does not fix the carpet extractor, I can walk you through some more advanced diagnosing. Just to make sure that we are on the same page, can you also please give me the exact model number of your Bissell? You may find this number on the back, or the bottom of the steamer. You had listed this repair under the Bissell ProHeat 2X 9500, but I'd like to just confirm with you that this is actually your model so I can give you the proper diagnosis. How old is the machine also?
I look forward to working with you to get this resolved. If this was helpful, please be so kind and rate my repair as helpful by clicking the 4 thumbs up icons in the top right hand corner. This is really what keeps repair professionals like myself coming back and providing free repair services. It's greatly appreciated.
Chris J.
GoVacuum.com
SOURCE: Instruction manual for a bissel proheat model
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that will give you all the information you need to fix your Bissell
Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
SOURCE: bissell model 1631 manual
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
go to this link:
http://www.bissell.com/customer-support/
there is a spot to put your model number in and you can download the owners manual. Good luck! Regards, Ross
