20 Most Recent Bissell LITTLE green Compact Multi-Purpose Cleaner Vacuum Questions & Answers
We had the same problem. After dissassembling the whole machine we could not find a clog or any other obvious problem. The manual suggests priming the pump by putting the solution reservoir in and out a few times. This did not help much. What did work was to raise the unit up a few feet above the trigger while depressing the holding the spray trigger. (That is, use gravity to fill the tube.) After solution was flowing freely, we turned the machine on and it seems to spray fine again.
Hope this helps
Bissell LITTLE... | Answered on Jul 01, 2019
You can download manuals from the Bissell website
Bissell LITTLE... | Answered on Dec 09, 2009
What worked for me is - put some water into the dirty water tank before you run it. My experience was, if I ran the machine with an empty dirty water tank, it stayed empty and didn't pull in any dirty water. If I put a little water in it beforehand, it helped seal the suction and get the thing started. Hope this helps!
Bissell Vacuums | Answered on Sep 04, 2019
There is almost certainly too much resistance somewhere in the machine's air flow. It could be that the filter (if fitted) needs a clean (or even replacing) or the bag/dust reservoir are full. If all ok, check that none of the tubes are blocked. (The air is being forced out of the relief channel due to resistance in the normal 'through flow' of air.)
Bissell Vacuums | Answered on Aug 07, 2019
I think you should take it to the manufacturer that made this product, so that their maintenance department can have a look at it and fix it.
Bissell Vacuums | Answered on Jul 11, 2019
Bissell LITTLE green Compact Multi-Purpose Cleaner Vacuum Logo
7 questions posted
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Bissell Vacuums
  • Bissell Vacuums
Most Popular Question
little green machine spray solution but
  • Vacuums
