Electrical Supplies Logo
K
Karuna Robertson Posted on Sep 29, 2014
Does anyone have the instructions which come with a micromark MM18033 500W Floodlight and WIREFREE PIR SENSOR? Thank you
Ian Clarke
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 20, 2014
 Ian Clarke
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
406
Points
Yes.
e-mail me at [email protected] and I'll send you the 4 sheets f.o.c.
Can the PnP brand 30w motion sensor led floodlight be set to come on permanently
The specific capabilities and settings of the PnP brand 30W motion sensor LED floodlight may vary depending on the model and design. However, in general, motion sensor LED floodlights are typically designed to operate based on detected motion and have a preset duration for illumination after motion is detected.
If you would like the PnP 30W motion sensor LED floodlight to remain on permanently, overriding the motion sensor function, you can try the following steps:
1. Locate the settings: Check if the floodlight has any accessible settings or switches that allow you to adjust its operation. This could be located on the fixture itself or on a separate control module if provided.
2. Disable or bypass the motion sensor: Look for an option to disable or bypass the motion sensor function. This might involve flipping a switch, pressing a button sequence, or adjusting a specific setting. Consult the product manual or contact the manufacturer's customer support for guidance on how to accomplish this for your specific model.
3. Connect the floodlight to a separate power source: If disabling the motion sensor function is not possible or practical, you can consider connecting the floodlight to a separate power source that provides constant power. This could involve bypassing the original wiring or using a separate switch or power outlet that remains on continuously.
It's important to note that overriding the motion sensor function may affect the energy efficiency and intended purpose of the floodlight. Motion sensor lights are typically designed to conserve energy by only activating when motion is detected, providing illumination when needed. Keeping the light on permanently may result in increased energy consumption and reduced bulb lifespan.
Always refer to the product manual or consult the manufacturer's instructions for the specific model of the PnP 30W motion sensor LED floodlight to ensure you understand its features and limitations.
Reset instructions for PIR floodlight
There should be a screw adjustment under the PIR unit. Clockwise direction increases the amount of time it stays on and anticlockwise decreases the amount of time it stays on. It's usually a small hole which you can see a slot in which you turn with a screwdriver.
User manual for fl09sbk light
It appears this device is rate 10 amps at 230 volts = 2300 watts.
Use at least #14 wire and 15 amp breaker.
Connect wire at connection point on light.
Unit appears to have a transformer, and might make humming sound.
There is override located somewhere on unit. Possibly as a button on the motion sensor
If infrared motion detector requires separate wiring connection, then use following wiring illustration:
http://waterheatertimer.org/images/How-to-wire-motion-sensor-230V.jpg
Motion sensor will probably have 2 settings.
1st setting for sensitivity, so it will not activate when cat walks up driveway.
2nd setting for time duration, selectable from 30 seconds to 7 minutes
ML FL09SBK IP44 36W Fluorescent PIR Floodlight c/w Lamp
IP44 Low Energy Floodlight c/w PIR & Override.
Black finish.
T4 twist and lock lampholder.
36 Watt 6500k T4 spiral compact fluorescent lamp included.
(replacement lamp - product code FL09L).
Electrical termination via 10 Amp connector block within secure enclosure c/w cord grip.
PIR detection range of 12 meters at 2 meter height from ground.
Detection arch of 160 degrees.
Time range 30 seconds to 7 minutes.
Manual override.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Does anyone know where I can purchase spare parts for a Micromark storage heater? I need the control knobs to replace the missing ones.
DEAR SIR
please search it near of your micromark area dealar you can buy it from there , and for know the micromark dealer location try to find it via internet then you can know it,s location .
hope answer the question
thank you
please vote !
Where can i get instructions for a Micromark MM52121 Tea Express?
Hi, did you find any as I'm in the same boat and as Micromark have folded can't find instructions anywhere
Thanks
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
