Model number WFS1071AW-7.5Kg
The pump filter is situated behing the white plastic kick strip on the front at the bottom of the machine.
Instructions for use Whirlpool UK
SOURCE: clean pump!
remove bottom panel torx or 7 mm nut driver needed.pump has "knob" turn counter clock wise ..have plenty of towels handy to unlock door first reach up to bottom of door lock tear shaped plastic tab pull down door will open
SOURCE: F9/FA Whirlpool 6th sense frontloader washer
F09 is "overflow failure" - check drain pump, pressure switch, blocked drain.
FA is the emergency shutoff switch that detects when water is pooling underneath the machine.
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06
Drive
Motor Tachometer Error
The
control is unable to properly detect motor speed and the
machine will shut down. If a failure occurs during high-speed
spin, the door will be unlocked after 3 minutes.
Thank you for writing to fix ya.
Best regards Richard
SOURCE: How to
I hope I am not sending this twice but it had trouble the first time, anyway here you go. If this is to small to read let me know and I can send you via email the entire book.
SOURCE: whirlpool 6th Sense displaying FP
On the lower front panel is a small door which may be behind the kick panel. Behind this door is the drain filter.. Do not undo this filter till you have emptied the machine, as any water in the machine will flow from the pump, when opened.. Leaning the machine back against the wall will help contain what water is left in the machine..
Undo filter, check and clean.
Check that a coin or hairclip has not fouled pump impellers.
If the impeller has come away from the pump shaft, the pump motor needs to be replaced.. A tech should be called for this job!
Good luck....Nomess
