FixYa.com
Whirlpool AWM8123 Front Load Washer
All Products > Whirlpool > Washing Machines
Problems with Whirlpool AWM8123 Front Load Washer?
Troubleshooting and Support
Solved Problems for Whirlpool AWM8123 Front Load Washer RSS Feed Post a New Problem
wont do anything
programme starts after about 10 seconds the door open light comes on and programme stops
1 Solution
washing machine belt replacement
How do I replace the belt on my Amana LWA60AW washing machine?
1 Solution
water leaking from bottom of machine
Water leaks out of bottom only on rinse cycle. Checked all hose connections and they are tight.
1 Solution
not fnishing wash cycle!
We found that the machine was not spining clothes dry so I changed the motor brushes, however this may not have been the...
1 Solution
roper washing machine roper rax7245kqo
Hi, My washing machine does not drain or spin at the end of the cycle. It just makes a buzzing noise, then stops. My...
1 Solution
Maytag washer that stopped working
The washer is not pumping water into the chamber when it is turned on, the water inlet valve is open. Is the pump gone?...
1 Solution
Hotpoint washing machine is so loud
I have recently bought a reconditioned hotpoint 1400 aquarius washing machine but it is so loud i am unable to use it...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Whirlpool AWM8123 Front Load Washer RSS Feed Post a New Problem
Door lock fault
Regardless of the cycle that you choose, the cycle will not start due to the door open light flashing, even though the...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Washer TypeWasher
Load TypeFront Load
Weight Capacity13.23 lb.
Wash
Wash Presets11 Wash Presets
Spin Speedsmax. 1200 rpm
Dimensions
Overall Depth23.43 in.
Overall Height33.46 in.
Overall Width (Display)23.62 in.
Warranty
Warranty1 Year Parts and Labor
Whirlpool Contact Information
Main support number1-800-253-1301
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
