I have a sanyo hdtv with integrated tuner and the tv code for it does not work on my innovage jumbo remote can you help me?
(Some universal remotes do not work with newer televisions, so the following instructions may not work)
Turn on the television.
Hold the 'CODE SEARCH' button for 3 seconds until the LED light is solid red.
Press the 'TV' button; the LED will blink once and remain solid red.
Point the remote at the TV and slowly and repeatedly press the 'ON/OFF' button until the TV turns off. (The LED will blink once each time you press the 'ON/OFF' button.
Once the TV turns off, press the 'ENTER' button; the code will be stored in the remote and the LED will turn off.
The remote should now work with the TV; test it out to see how it works.
(The remote may be too old for your TV; if the above instructions don't work you may need to get a newer remote.)
SOURCE: admiral tv/vcr, innovage jumbo remote
YOU CAN USE EMERSON CODES FOR YOUR ADMIRAL TV AND TV / VCR COMBOS, MY COMCAST REMOTE ACCEPTED 11911. SOME REMOTES NEED FIVE NUMBERS AND MY ADMIRAL ONLY HAS THREE. SO I USED AN EMERSON CODE AND IT WORKED MOST OF THE BELLS, NOT ALL WHISTLES WORKED BUT I DIDN'T HAVE TO GET UP TO TURN IT ON, CHANGE THE CHANNEL OR THE VOLUME. MY KIDS WON'T DO IT ANY MORE!!
GOOD LUCK!!!!!
