20 Most Recent Innovage Jumbo Remote Control Questions & Answers
Hola, tengo un control master RM-UNI4 pero perd? los c?digos, alguien sabe cual es el c?digo para una tele Panasonic, majestic y para un DVD Sony?
Innovage Jumbo... | Answered on Nov 05, 2018
I had the same problem Johny. Everybody wants to tell you how to program the one with the CODE SEARCH button. Here\'s how to do the one without. Press and hold the item button you wish to program (TV, DVD etc anyone of them can be used for anything) until the LED lights and stays on. Turn the item on manually and point the remote at it and push the power button. When the gadget turns itself off, immediately press the item button again. You can recall the code by pushing the item button until the light turns on again and then press DISP. Now push the number buttons (random is OK). As you hit the correct number of the code, the LED will flash until the four digit code is entered then the LED will go off. You may wish to try for more codes as some function better than others that just simply "work".
Innovage Jumbo... | Answered on Aug 27, 2018
Mine says ALL OFF where the code search button should be -.- what do I do now?
Innovage Jumbo... | Answered on Dec 26, 2017
it stands for DIGITAL TELEVISION CONVERTER
Innovage Jumbo... | Answered on Feb 26, 2017
You have to setup the remote control to cablebox. If you wish to get more details about the setup proceedings to jumbo universal remote control, check this link. Setup proceedings to some popular model remote controls, including jumbo remote control is given in detail. Pull up older posts there.
Innovage Jumbo... | Answered on Aug 20, 2016
go to www. remotecodelist.com and download for free the code
or go to www. manualslib.com and download the owner manual
God bless you
If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
click "codes list" to download the pdf for the 4 and 5 device remote code list, this is asuming you have either the 4 or 5 device remote however.
Innovage Jumbo... | Answered on Aug 17, 2016
Hello
Three digit remote codes for Zenith TV with Innovage Jumbo remote control are:
004 / 005 / 006 / 019 / 196 / 004 / 051 / 083 / 152 / 153 / 154 / 210 / 217
OK.
Innovage Jumbo... | Answered on Jul 01, 2016
http://www.rockabilly.net/files/manuals/jumbo-remote.zip
Innovage Jumbo... | Answered on Apr 06, 2016
02819,02894,028810. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
Innovage Jumbo... | Answered on Jul 27, 2015
Look for the codes at the Innovage web site. Not the problem? Be more specific.
Innovage Jumbo... | Answered on Jul 02, 2015
0082,0085,0028,0021 are the general codes to use with Akai brand TVs. Try these codes. For more information, check these links. http://electrohelponline.blogspot.com/
Innovage Jumbo... | Answered on May 08, 2015
Here are the codes,for the Tv,004,008,009,062,068,069,074,075,077,089,163,165,,if it is a combo,,062,115,001,...the dvd is ..173,183.....hope this was helpful...
Innovage Jumbo... | Answered on Mar 22, 2015
I have found the iWave, Innovage, and generic "JUMBO" are the same remote.
Here is the link to the manual. It looks like it has a easy to do auto-search button, for TV's not on the list.
http://www.vat19.com/dvds/jumbo-universal-remote-manual.pdf
Good Luck
Innovage Jumbo... | Answered on Mar 17, 2015
Type Innovage Jumbo Remote Universal Reote in your search engine and you will find the Innovage Remote website or you can go to ehow.com and should be able to find the instructions.
Innovage Jumbo... | Answered on Oct 24, 2014
Jumbo remotes are basically the same, regardless of the name on them. Assuming you do not have a copy of the code list, begin by turning ON the device you want to control. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button. Press and immediately release the desired mode (device) button. The red indicator will blink once. Aim the remote directly at the device you wish to control and press the ON/OFF button repeatedly (up to 300 times!) until the device changes channel. The red indicator blinks off with each button press. When the device changes channel, press the ENTER button. Programming is much easier using direct entry of the code.
Innovage Jumbo... | Answered on Oct 02, 2014
2809,2885,2800.
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Innovage Jumbo... | Answered on Aug 27, 2014
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Check your present remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Viewing it in "Mosaic" or "Sidebar" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Innovage Jumbo... | Answered on Aug 07, 2014
Innovage Jumbo Remote Control Logo
606 questions posted
Top Innovage Televison & Video Experts
Jose Ma DM.
Jose Ma DM.
Ben Beharrell
Are you an Innovage Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Innovage Televison & Video
Most Popular Question
code seiki tv
  • Televison & Video
