Play station struck by lightning need help getting it back on it won't come on at all.
SOURCE: PS3 IS STUCK ON THIS MENU AREA WHERE YOU CAN FIX SETTINGS
re boot ps3.hold down on off button for 1 blep and than for 2 bleps . then re boot ps3
SOURCE: ps3 games all freeze
yes me too mine keeps freezing and comes up with red circles on the screen somtimes, try and visit the site www.ps3fixing.com or www.playstation.co.uk hope it helps you mate, i have to trade mine in.
SOURCE: PS3 WON'T PLAY BLU-RAY DISCS
The problem is all in the settings. You probably have a 1080i television that cannot display in 1080p. To fix this go to the main menu and go to:
Settings:
Video Settings
Then Blu Ray Disc and make it turn the Display BD in 1080p 24hz or whatever. Once you do that, start the Blu Ray Disc again, and you should be able to watch it. This all happened because your tv doesn't display 1080p.
Hope this helps!
SOURCE: ps3 will not play any games
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
SOURCE: PS3 wont play blue ray or PS3 game discs
Please check the region code on the BD or DVD. It should match the region code set in the system. Otherwise the disc will not play
