Washing Machines Logo
A
Anonymous Posted on Aug 17, 2014
Frigidaire troubleshooting what does it mean when there is a yellow light with a lock button on control panel ?
  • Official Brand Answer 4,342 Answers
  • Posted on Aug 19, 2014
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1467952
Points
5907
Good morning friend, thank you for your post!
I understand that you are asking what the yellow light with a lock button on your Frigidaire washer means. Typically a lock symbol stands for control lock. I notice you did not provide your model number, if you comment back with your model number I would like to research to verify the information. Normally you can locate the serial tag (which lists your model number) on the upper front of the door frame on a front load washer. If you own a top load washer you would normally find the serial tag on the inside of the lid, on the right side. I look forward to your response.-Matt
4 Related Answers
Anonymous
  • 1294 Answers
  • Posted on Mar 26, 2009
SOURCE: Frigidaire affinity atf6000es1 - control panel locked
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines hope it may for you..............And please rate me if helped
Anonymous
  • 1294 Answers
  • Posted on May 14, 2009
SOURCE: control panel locked, won't unlock.
Press & hold the 'end of cycle' button on the right side of panel for 3 seconds. Child lock button, you do the same thing again & it locks. You don't want kids bathing in the machine, no. Pl rate me nice.
  • 6688 Answers
  • Posted on Sep 22, 2011
SOURCE: my frigidaire front load washer
Is the message "LOL" or "LOC"? I suspect the child lock "LOC" has been activated. To toggle this off, press and hold Options and Select for 10+ seconds. This feature prevents someone from accidently starting or changing a cycle selection.
There is a small padlock icon in the middle of lines linking the two buttons that let you toggle the child lock on and off.
There are two Frigidaire washers with the model ATF6000ES (the S is followed by a 0 or a 1). The manuals for both are available here: http://www.frigidaire.com/manuals?model=ATF6000ES . The child lock feature is described in the Operating Instructions. For the ATF6000ES0, the direct link to the appropriate manual is http://manuals.frigidaire.com/prodinfo_pdf/Webster/134604400.pdf . See page 2 under Washer Features.
I hope this helps.
chrispolkele
Electrolux
  • 4342 Answers
  • Posted on Jul 24, 2012
Our people make the difference
    Verified Fixya Pro
    SOURCE: frigidaire washer model ATF6000ES1 door not locking, the door closes, but it's not recognized by control panel.
    You are having a problem with the door latch sensor indicating everything is connected correctly. Check to make sure your door is not sagging and then make sure the door latch is not broken or cracked.
    Maytag fridge bepping lights out MFI2568AES...fridge and freezer working..what could it be... Beeping all night long..
    Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
    Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
    Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
    Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
    ·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
    Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
    Read more :
    Cause of Beeping Noise in Frigidaire Refrigerator eHow Refrigeration System Basics Chapter 1
    Samsung refrigerator alarm beeping continuously
    Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
    Fridge keeps bleeping
    Model E402b. Why is the alarm going off?
    Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
    Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
    I have a frigidaire side by side model GLHS37EHSB7 refrigerator makes a continuing beeping sound what could be wrong?
    Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
    Fridge & freezer lights and the water display light beep and flash 10-12 times every few hours. Simultaneously a fan motor starts and stops. Any one know what needs to be done to remedy this?
    Refridgerator beeps
    Keeps beeping, but not overfilled
    Smeg refrigirator keeps beeping without stop
    MY FRIGIDAIRE FRIDGE IS BEEPING AND NOT STAYING COOL
    Top Washing Machines Experts
    john h
