RCA L26WD26D 26 in. LCD TV Logo
Posted on Jul 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY RCA JUST STOPPED TONIGHT,WENT TROUGH ALL THE
MY RCA-(L32WD22) JUST STOPPED WORKING TONIGHT. I WENT TROUGH ALL THE TROUBLE SHOOTING TIPS, NO LUCK THERE. NO LIGHTS, NOTHING'S HAPPENING. HELP!
Anonymous
Level 3:
Genius:
  • Master 1,139 Answers
  • Posted on Jul 01, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1139
Questions
Helped
413605
Points
2179
This sounds like a power supply problem. This is usually caused by dried out capacitors on the power supply board. If you open up the TV try to look for capacitors that appear to be bloated or puffy on the top. Some of them may have even exploded. I would however suggest that you have a TV technician examine this TV and repair it. This is because it requires specialized equipment to do the job properly.
I hope this Helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Anonymous
Level 3:
President:
  • Master 1,077 Answers
Anonymous
Master
Level 3:
President:
Answers
1077
Questions
Helped
774948
Points
4687
Most likely the TV has a power supply related problem. Or, it maybe something simple like a blown fuse inside the TV.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
2answers
I have no remote for an rca l32wd22 hdtv lcd tv and cannot find the inputs to change to HDMI?
Unfortunately, the L32WD22 doesn't have an Input button on the front panel of the TV. You need a remote control that matches the Input code for the remote. Here's one link to a remote that should work: http://remotes.com/store/rca/l32wd22.html . Other universal remotes may work if you find the correct code if the remote has an Input or Source button.
I hope this helps.
2helpful
2answers
Light comes on (flashing amber most of the time) but a black screen and now sound. Happened suddenly. Working fine until then.
My friend Maurice gave me a L32HD31YX16 with the same problem, no picture no sound, after four hours of research and trouble shooting, no schematics.
I had no +12 and no +24 volts on the power supply board. I did have the +5V.
The repair is an 85 cent fuse under the blue transformer, There is a 200mA fuse, green with a "C" on it, at location RB8 (1206 package).
I went to the shack bought a 250mA glass fuse and holder for 5 dollars just to get it done. So far the unit has run for an hour.
IRB
3helpful
2answers
I have a L32HD31YX16.I turned it off before I went
Talis
Just to let you know that these tvs had bad power supplies.
Take your unit to a Service Center where the fix tvs.
Since there are no manuals to repair these, they will geive back your tv with a work order.
With that Work Order call 1-877-297-8391 and they will give you a new tv
1helpful
2answers
RCA L32WD22 with no picture.
The backlight has failed. May be the power supply for it, the inverter board or the lamps. Not something you can fix unless you are a tech.
I have a rca l32wd22 screen weht black with no
Aboyd992,
Take your tv to a service center and ask them to fix it. If they cant...
Have them make out a work order and then you call 1-877-297-8391. The people at the other end ot the tele number will give another tv
3helpful
2answers
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
3answers
L32wd22 power supply
Hi and welcome to FixYa,
Based on your requirement, pls try:
Good luck and Thank you for using FixYa. Happy Holidays.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
