Home | Coleman | Air Conditioners
Coleman Mach 15 Air Conditioner
Problems with Coleman Mach 15 Air Conditioner?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Top
Experts
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Coleman Mach 15 Air Conditioner RSS Feed
Click here to get instant support from our best Experts!
View More Results for Coleman Mach 15 Air Conditioner
Questions and Unsolved Support Problems
Unsolved Problems for Coleman Mach 15 Air Conditioner RSS Feed
Answer
We just bought a 1996 motorhome that has the solar panel on top of the ac unit but someone has... (More)
Answer
I built a 70W solar panel. The cells are housed in a wood frame and topped with plexiglass put down... (More)
Answer
appears to be condensation leaking from the roof A/C in 2009 Pleasure Way Plateau RV. Leaks on back... (More)
Find a Manual
Coleman Mach 15 Air Conditioner Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
USEFUL TIPS FOR YOUR LAPTOP
CLICK HERE TO GET USEFUL TIPS FOR YOUR LAPTOP written by zeinbai
Replace the unit? or Replace the compressor? Split AC or Heat Pump
I had this fellow ask why he couldn't find any thing about id model number for buying a replacement out door ac unit. The answer I game him is part... written by farfield
Relay Wiring tips and tricks Simple circut. What to look/lookout for
Typically if you want a circuit completed when energized you use C (Common) and NO (normally open). This means that the contact will close when... written by farfield
Don't jump to "Its low on charge; because its froze up"
A low charge diagnosis for instance can be miss read if the evaporator is iced up or has any ice in or on it. A sticking thermostat, relay, or... written by farfield
How to Trouble shoot Low Voltage Controls on AC-Heat
What I have always been told is if your 24 volt side burns out check the high volt side if the hi volt side burns out check the low volt side. A... written by farfield
COMPRESSOR check outs semplified.
If your wondering how to check out your refrigeration compressor; Modern Compressors have two operations that have to work together just to run.... written by farfield
Air Filter changing - easey and often
Examine the air filter at the beginning of each cooling and heating season and at the beginning of each day light savings time change. Write the date... written by farfield
AC DRAINAGE PIPING REQUIREMENT
Slide 71 .O {color:black; font-size:149%;} a:link {color:#CCCCFF !important;} a:active {color:#3333CC... written by bobotfel
WikiManual
(Post a New Chapter)
How to Keep the Upstairs of Your Air Conditioned Home Cooler
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps. Steps: 1. Add attic insulation.... by wikihow
How to Build Your Own Air Conditioner
If your tap water is cool, you can air condition a room with it at minimal cost. Steps: 1. Obtain a radiator from a small car such as a Honda Civic,... by wikihow
How to Check Your Air Conditioner Before Calling for Service
Steps: 1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for Mach 15 Air Conditioner
Nationwide | | Website
Service and Repair, System Maintenance, Advantage Mem... Read More
Featured Listing
ARS
Nationwide | 8668003823 | Website
When it comes to air conditioning systems, ARS® pro... Read More
Featured Listing
San Francisco, CA 94101 | 415 8616274
All Makes & Models,Buses,Computer Rooms,Chiller Sys... Read More
475 Barneveld Ave, San Francisco, CA 94124 | 415 6487135
Air Conditioning,Air Conditioning,Air Conditioning & R... Read More
1967 Ocean Ave, San Francisco, CA 94124 | 415 4682260
Factory Authorized Service,For Service Call,Sub Zer... Read More
2248 Jerrold Ave, San Francisco, CA 94124 | 415 2827940
Contractors,Distributor,Factory Authorized Dea... Read More
Find an Expert
Meet our 2554 Air Conditioner Experts
milten1
#1: milten1
Rank: GuruGuru
Rating:  90%, 434 votes
Solutions:  1303 (652 Votes in the last 30 days)
Experience: 15 years field experience and 5 years navy training
dmftrucker
Rank: GuruGuru
Rating:  88%, 331 votes
Solutions:  1444 (516 Votes in the last 30 days)
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
roniecon
#3: roniecon
Rank: GuruGuru
Rating:  88%, 542 votes
Solutions:  1827 (353 Votes in the last 30 days)
Experience: A S E certified /35 years experience
techbuster
Rank: GuruGuru
Rating:  90%, 429 votes
Solutions:  963 (350 Votes in the last 30 days)
localwonder
Rank: GuruGuru
Rating:  92%, 2659 votes
Solutions:  4695 (315 Votes in the last 30 days)
Experience: I have yrs of experience dealing with many situations.
57 varieties
Rank: GuruGuru
Rating:  88%, 404 votes
Solutions:  1270 (285 Votes in the last 30 days)
Experience: I have been solving problems and fixing things for over 30 years!
justaskjoe
Rank: GuruGuru
Rating:  85%, 1840 votes
Solutions:  3482 (236 Votes in the last 30 days)
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
SRF518
#8: SRF518
Rank: GuruGuru
Air Conditioners ExpertExpert
Rating:  88%, 59 votes
Solutions:  224 (224 Votes in the last 30 days)
Experience: Licensed Master Electrician for 35 years. Have a vast knowledge of mechanical items.
rtpflh
#9: rtpflh
Rank: GuruGuru
Rating:  91%, 153 votes
Solutions:  487 (204 Votes in the last 30 days)
Experience: life experience
1fastbob
#10: 1fastbob
Rank: GuruGuru
Rating:  90%, 77 votes
Solutions:  275 (203 Votes in the last 30 days)
Experience: Former electronics tech. Avid do it yourselfer. Home construction, wiring. I am a motorhead.
Find a Warranty
Coleman Contact Information
Main support number1-800-835-3278
Email supportconsumerservice@coleman.com
Describe your problem:
Sponsored Links
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
