Question about Brother IntelliFAX 2800 Laser Fax
Brother 2800 fax
WE have a dial tone on the phone line,but no fax tone on the fax machine
  • 159 Answers
Make sure you have the telephone cord plugged into the jack marked "line"
Posted on Jan 01, 2008
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
The fax machine will not send a fax. What should I check to fix this problem.
The only thing that could stop you from sending a fax or not get a dial tone, would be the connection to the phone line. Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack
Apr 08, 2010 | Brother IntelliFAX 2800 Laser Fax
Fax machine not receiving faxes
First pick up the handset and make sure you have a dial tone on the line.Second thing to check is to make sure that your fax machine set to "FAX" mode,not"PHONE"mode, and it is in auto receive,not manual receive mode.
Sep 09, 2009 | Brother IntelliFAX 2800 Laser Fax
Multifunction phone/fax/copier machine
Hi sythonk
1. Make sure you have a telephone cable connected the jack labelled "LINE" on your brother machine.
Go through the Menu on the LCD, Initial setup, dial tone, choose the correct dial tone PULSE or TONE.
Exit from the menu.
Pick up the handset on the fax machine, and dial your nuber to make a phone call. (To send a fax, dial the number without lifting the handset.)
Hope this will work for you. If it solved your problem, give a please rating
Sep 06, 2009 | Brother Office Equipment & Supplies
Fax machine will not pick up
first make sure there is a dial tone on the line, next reset up the machine in send and receive mode. if all of this fails, then you have a bad ncu board which is the phone board
Dec 08, 2008 | Brother IntelliFAX 2800 Laser Fax
No dial tone
Very strange that there a no other symtoms.
Are you sure you are plugged into the LINE port of the fax machine?
Oct 18, 2008 | Brother IntelliFAX-2440c Plain Paper...
Brother lntellifax 2800
If you have a hand set try to use it as a phone. If no dialing tones are present check the phone line connection. If the fax is well connected there is a good chance that you need a part for the machine.
Jun 23, 2008 | Brother IntelliFAX 2800 Laser Fax
We can't send or received faxes
Just a suggestion. This effect can happen if you have plugged the line cord into the tel jack instead of line jack.
Oct 30, 2007 | Brother IntelliFAX 2800 Laser Fax
Outgoing fax never goes
Do you have the same problem with different numbers that you fax to? Are you usinga voip phone service? I use Vonage and have a lot of trouble with faxing. Call the number you are faxing to with a different phone and listen for a fax tone.
Aug 16, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
70 people viewed this question
James Cagle
James Cagle
Jim Keysor
