I ve got ice on the back wall of the freezer and the its not staying cold
SOURCE: Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
SOURCE: Freezer cold- Fridge not. Ice build up on freezer
I really believe your adaptive defrost located inside the fresh food compartment and inside the control panel is defective. It puts your refrigerator on a timely defrost and if defective this problem you listed in your post happens. Yes we may need to also check the defrost heater and defrost thermostat but with my experience with that type of Adaptive Defrost Control is famous for its failure.
ADAPTIVE DEFROST CONTROL Part Number 61005988 You can find it located on two of my websites. Some models like yours came with a Defrost Timer. We will need just look inside the control panel and see for sure. Here is a photo of the Adaptive defrost. If you should need to contact me please send an email or try to answer here. Problem is I don't get notifications when someone comments. [email protected]
Please rate and ask me as much as you like. Thank You, Sea Breeze
Part 61005988
http://appliancepartseast.blogspot.com/
http://servicepartstec.blogspot.com/
SOURCE: maytag fridge water dripping from inside freezer side
This sounds like the evaporator drain may be clogged either in the freexer compartment or at the outlet to the drain pan under the unit. Every defrost cycle the defrost element makes water by melting the ice on the evaporator coils. If the drain is clogged there is no other place for the ice to go. Many times the drain may just have ice buildup in the evaporator drain funnel that can be corrected with a manual defrosting.
To do this manual defrosting all you do is first unplug the unit then remove everything from the freezer compartment. After that place a fan blowing into the freezer section for a little over 2 hours. Please NOTE this will make more of that pesky water mess so be ready to tend to the mess as it presents itself.
After the 2 hour fan session plug the unit back in and reload the freezer compartment with previous content. Monitor for the possibility of the water manifeting itself again.
In addidtion to the above there is a drain pan catch basin in the bottom of the unit near the compressor. They are usually white plastic on Maytag units and not to rugged. Make sure that the drain pan is not loaded with debris. There is about a 1/2 inch diameter opaque plastic line that drains into the catch basin. That is the Evaporator darin tube. Ensure the very end of the tube does not have caked up debris in the very end of the tube. Sometimes this tube cakes up and then the debris dries hard inside the tube near the end. Make sure the tube is free of foreign objects and clean.
After all of the above / cleaning and clearing / manual defrosting it is still making water then most likely the lower panel under the defrosting element / evaporator may have become disconnected allowing defrost cycle water from the melted ice into the freezer compartment vs exit via the drain. To fix the disconnected power metal panel problem the rear freezer panel would have to removed to re-attach / repair the metal panel that guides the water into the evaporator drain.
Thanks for using FixYa.
Kelly
SOURCE: Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Testimonial: "Thank you. We will work on that and see what happens. "
