Troubleshooting & Support
Hot Topics:
- noise
- ice maker
- Repair Manual
- mfd2560hew
- water dispenser
- fan
- manual parts
- control board
- Refrigerator
- ice maker water...
- thermostat
- handle
- evaporator fan
- water
- damper
- control
- crisper drawer...
- open
- COMPRESSOR...
- high voltage...
- mfd2561
- adjust
- defrost timer
- defrosting
- manual
- ice
- evaporator fan...
- mff2557heb
- not freezing
- freezing
- View All »
Problems & Solutions
My refrigerator works only for a few days and then
Hi eric_langdon, This complaint is usually the result of a defrost problem. The first thing to check in this case is the freezer area. ...
My refrigerator is not working, but my freezer is
Usually there is a air flow problem from it not defrosting(all the evaporator coils are frosted up with moisture preventing air flow-defrost...
refrigerator not cooling
Hi, Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that...
french doors open each other, or when you close
The fridge is trapping air inside and causing this, simply hold the doors shut and do it slower .
fridge area not cooling properly
Hi, Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling Refrigerator not...
freezer working well fan stoppped and refrig not
There is a new replacement fan available for your refrigerator, it comes as a kit with a new mounting bracket. They had a lot of issues with...
MFD2560HEW Bottom freezer french doors. Top shelf
At this point I am not sure if your Auto Damper that regulates the cold air is stuck closed or if the thermistor that controls the damper is...
freezer works, fridge wont get cold and fridge
Probably have a bad freezer fan or the unit is not defrosting. You can easily hear the fan running.
Fridge wont get cold
DEFROST HEATERS IN THE FREEZER. IF THERE IS FROST ON THE BACK WALL INSIDE THE OF THE FREEZER SECTION. YOU THEN HAVE A DEFROST PROBLEM....
Maytag refrigerator isn't cold.
When a defrost timer, or heat strip or terminator go bad, the evaporators coil ices up soon blocking any airflow through the evaporators...
the freezer is working well but the fridge is not.
Hi, Here are a couple of tips that I wrote that will help you figure this out... http://www.fixya.com/support/r3771673-defrost_refrigerator...
Maytag Ice20 refrigerator
Thanks, Solution #3, for the phone number ((800) 688-9900)! We, too, have the Ice2O refrigerator, and the HV Board started the disco light...
Hi, I have a Maytag (MFD2560HES) fridge. The
you need to check and make sure the evaporator fan is running in the freezer compartment while the unit is in the cooling mode if it is then...
FRIDGE IS WARM
CHECK THE FAN ALL THE COOLING IS DONE IN THE FREEZER SECT. THE FAN CIRCULATES THE AIR TO THE FRESH FOOD AREA. IF ITS FROSTED UP IN THE...
temp control is flashing and clicking
you will have to have the jazz board replaced . very common problem . i have one in my own home . . this is the main control. and the only...
See all Maytag MFD2560HES Bottom Freezer French Door Solutions
Unsolved Problems
Maytag Refrigerator # MF12569VEM
Maytag Refrigerator # MF12569VEM I have this refrigerator and conjela me things and I grab fruit ice and soda water and...
the ice makers is leaking down onto the drawer...
the ice makers is leaking down onto the drawer rails and making a mess onto the track does the ice maker need to be...
panel and ice flap firing
Does not reset after unplug for a brief time
freezer door stuck
We bought this fridge used and everything seems fine, the only thing is the bottom freezer door will not open when it is...
maytag MFD2560HES water dispenser not working ice...
water dispensor not working
I have a Maytag Bottom Freezer French Door...
I have a Maytag Bottom Freezer French Door Refrigerator. The freezer is developing ice on the bottom and then water...
the right french doors opens when closing the left...
even when the left door is closed gently it the right opens an inch or 2. I checked the door seal and it is clean.
See all Maytag MFD2560HES Bottom Freezer French Door Problems
Manuals & Guides
TopDo you have a manual for Maytag MFD2560HES Bottom Freezer French Door Refrigerator? - Upload it to FixYa!
Upload a manual for Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Specifications
TopKey Features
Full Product Name:Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Type:Bottom Freezer
Type:French Door
Total Volume:24.8 cu. ft. / 702 liter
Fresh Food Volume:17.3 cu. ft. / 490 liter
Freezer Volume:7.5 cu. ft. / 212 liter
Ice Maker:With Ice Maker
Total Number of Shelves:4
Fresh Food Compartment
Fresh Food Shelves / Bins:Vegetable Bin (Controlled Humidity) x 2
Fresh Food Shelves / Bins:Snack Drawer
Fresh Food Shelves / Bins:Egg Storage
Fresh Food Shelves / Bins:Dairy Center
Fresh Food Shelves / Bins:Spill Proof Shelves
Fresh Food Shelves / Bins:Split Shelves
Shelf Material:Glass
Door Opens:Opens to Left and Right
Light:Yes
Freezer Compartment
Shelve / Bins:Bin x 2
Ice Maker
Dispenser:Water
Dispenser:With Water Filter
Convenience
Exterior Color:Stainless Steel
Extra Features:Adjustable Rollers / Levelers
Energy
Amperage Rating:15 Amp.
Energy Efficiency:Energy Star Compliant
Dimensions
Overall Depth:31.75 in.
Overall Height:69.88 in.
Overall Width:35.63 in.
Warranty
Warranty:1 Year Parts and Labor
Warranty:5 Years Labor (Compressor)
Warranty:5 Years Parts (Compressor)
What's your problem?
Fix-O-Meter
45,351
45,351 people have viewed this product
- 594 people asked about this product.
- 211 people found solutions for this product.
- 23 people have added this product.
Pins on the...
How to fix your...
Ice Maker...
