SOURCE: Fuser replacement on Brother MFC 8860DN
Yes I did it myself, however I am savvy with most hardware, I wouldnt suggest it for the novice. It cost around $NZ245 for the fusing unit, which from doing a quick search online is about the same in most countries.
SOURCE: Need info on replacing Laser & Fuser for Brother MFC 8860 DN
i have the same problem there is a phone number in the maual wich is the Brother support center 18772768437, after a few unnecesary question they will give a phone number of a company near your area that do maintenances services to copy machines, they are the one who will replace those parts, well at least that is what i think i just called them they are getting the prices, good luck.
SOURCE: Hae brother MFC-8500 and just replaced
This is an easy one. With the power on, open the front door, where you installed the drum. Press the CLEAR button. The display will ask something like, "Change Drum? Press 1 for yes. Press 2 for no."
Press 1.
Close the front door.
Testimonial: "thanks for your help...this is an awesome way to get help!.....although I didn't think to go online and look up the manual.but with dial up it's slow"
SOURCE: Brother MFC 240C clear Machine Error 46, IT HAS
In order to resolve the issue we try to resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
This will resolve the issue.
SOURCE: Just replaced ink cartridges on my Brother MFC
Hi there you can refill Brother cartidges, like other printers it will not have it sorry.
This is the only way you can trick it.
There are only a few steps you need to do to reset a Brother printer ink cartridge and once you do it, you will be up and printing in no time. There are actually two things that a Brother printer uses to detect ink and you can manipulate one or the other.
Instructions
Things You'll Need:
· Black electrical tape, masking tape or duct tape
1. Step 1
Identify the printer If your printer uses memory, you can tell which printer you have by looking at where the cartridge goes in, if you see two "eyes" and a part of the cartridge goes in between them, follow Step 3. Otherwise, continue with Step 2.
2. Step 2
Clear the memory by taking the cartridge out and unplugging the unit for 30 seconds. Then, plug it back in and put back in the cartridge. You may need to do this five times, as the memory holds the last five cartridges.
3. Step 3
If the Brother printer has "eyes" where the cartridge goes, you will need to block in between them with a piece of tape so that it thinks the cartridge is always full. Simply put a piece of tape on the piece of the cartridge that goes in between the eyes to block the path of the infrared beam
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
