Whirlpool AKR 687 IX Logo
A
Anonymous Posted on May 13, 2014
Where to find light bulbs for Luftig range hood?
Replaced bulbs PL-C 13W 4pin in range hood bulbs do not light up?
That is a big bulb for a range hood! I would get a second bulb and try it. You will need a spare because Compact Fluorescents are being phased out due to the polluting mercury in them. If that new bulb doesn't work either, you will need to replace the ballast unit. They come in one small box.
https://www.lighting.philips.com/main/prof/lighting-electronics/fluorescent/fluorescent-electromagnetic/bpl-em-ballasts-for-cfl-pl-t-pl-s-and-pl-c-lamps/913710121550_EU/product
1helpful
2answers
How do i change a bulb on a zephyr verona range hood
I could not turn the bulb, and the rubber glove approach did not work. I unscrewed and removed the middle cover, which meant I could easily reach inside and turn the whole light bulb fixture.
Viking range hood dimmer switch
Sorry we have no part locating services here at this website.
How to change the light in technika range hood
Safety is important when is comes to replacing a light bulb of a range hood. The first thing to remember is to turn off power and allow lights to cool before proceeding.
home light
How do you remove the light bulb cover in a fivestar 48
You remove your incandescent light bulb and insert your automotive LED light bulb.The LED lights cover the landscape area for people to be able to see.
home light bulbs
Burned out light on bertazzoni hood
Here is how I fix this problem in case someon is still looking for an answer: 1. Turn power to hood off at electric panel 2. Remove light diffusers - these are the round glasses under hood covering the light bulbs. Turn the light diffuser counter clock wise to remove 3. Remove the burned out light bulbs 4. Install the new light bulbs
12helpful
3answers
How do I remove burned out light bulbs from zephyr range hood? What do I replace them with?
What model range hood do you have? To remove most of the bulbs from a Zephyr hood, wait for the bulb to cool after use. Then rotate the bulb counter-clockwise about 60 degrees (less than a quarter turn) and the bulb should drop down. If you have problems turning the bulb, try the glass suction cup that comes with the hood or a rubber/latex glove grip. Sometimes a rubber jar grip will also work.
The one way to find out your range hood bulb may be to remove one and look at the side/back. The bulbs are labeled. Otherwise, check your manual. Zephyr has the manuals for most of their ranges here: http://zephyronline.com/customer_support . Use the drop-down menu to select your model.
Different hoods use different bulbs. For AK6500, 6536, 6542 Cyclone hoods, purchase type: 4OR 14 mini flood light bulbs. For the AK2500, 2536 hoods, you need to purchase type GU 10 halogen bulbs. For the Anzio models, including the ZAN-E30AS, get a GU-10 50W halogen bulb.
I hope this helps.
1helpful
I have Sakura kitchen range hood model #c R706, R727 and Want to know how ro chaneg teh bulb. Thanks
I found all the part I needed for my Sakura range hood at http://www.rangehoodking.com/ they had everything I needed. of cos that light bulb too!
1helpful
2answers
Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
