Question about Bertazzoni K48HERX 48" Kitchen Hood
Burned out light on bertazzoni hood - Bertazzoni K48HERX 48" Kitchen Hood
Posted by Maura Arcos on
  • 1 more comment
  • Maura Arcos Jan 05, 2012
    How do you replace halogen bulb on bertazzoni 36" range hood?
  • Hector Duran Jul 30, 2013
    accidentally clicked submit. Here are the additional steps
  • Hector Duran Jul 31, 2013
    5. Turn power back on; 6. Test the lights; 7. Install lamp covers or light diffusers and you are done. See this video:http://m.youtube.com/watch?v=ssTCGPj9CWY for how to replace the light bulbs. While not the same hood model, the steps are similar. Also see the image attached to understand what type of bulb you will need. Hope this helps.
Hector Duran
Here is how I fix this problem in case someon is still looking for an answer: 1. Turn power to hood off at electric panel 2. Remove light diffusers - these are the round glasses under hood covering the light bulbs. Turn the light diffuser counter clock wise to remove 3. Remove the burned out light bulbs 4. Install the new light bulbs
Posted on Jul 30, 2013
How to remove oven door
Bertazzoni X366GGVX Stainless Steel Gas Range Remove ...
www.fixya.com > ... > Bertazzoni X366GGVX Stainless Steel Gas Range
Bertazzoni X366GGVX Stainless Steel Gas Range"remove oven door" Questions. Question about Frigidaire Kitchen Ranges. 1 Answer ..
Aug 11, 2015 | Bertazzoni Kitchen Ranges
What is the wattage for the halogen lights for the hood. There are two lights but they do not list the wattage
As a general rule, the size and shape of the bulb will determine the wattage. Match it up with ones in the store, the value can be slightly higher or lower but it will still work just fine. Halogen bulbs burn out much quicker if you handle them without gloves or tissues. The oil from your fingers will cause them to burn out faster.
Jul 11, 2014 | Bertazzoni K30 PRO X 30" Kitchen Hood
What is the wattage for the halogen light for my hood?
Must be no greater than 30 watts. As it is a standard oven bulb I suggest you just remove the current one and bring it to a local hardware store.
My new Bertazzoni range leaves soot on my pots which gets on everything in close contact.
Run it through a cleaning cycle, residues from manufacturing could be causing your problem.
Apr 21, 2014 | Bertazzoni Heritage 48 Inches 6 Burner...
Bertazzoni hood replace bulb
First remove cover to access the bulb, pull bulb straight down being careful not to break it. to replace w/new bulb, remove bulb from package, be sure to use a cloth or some type of glove so as not to get oils from your fingers on the new bulb as this will create a hot spot on the new bulb and shorten the life of the bulb. Install the new bulb by inserting into the fixture by gently pushing the bulb into socket.
Hope this helps
Apr 19, 2014 | Bertazzoni K30 PRO X 30" Kitchen Hood
NO POWER TO HOOD
Check gfi or breaker
Dec 10, 2013 | Bertazzoni Kitchen Ranges
Bertazzoni K48HERX 48" Kitchen Hood Logo
2,426 people viewed this question
Top Bertazzoni Kitchen Ranges Experts
Dennis
john h
Andrew Taylor
Andrew Taylor
Are you a Bertazzoni Kitchen Range Expert? Answer questions, earn points and help others
