20 Most Recent Whirlpool GERC4110PS Kitchen Range Questions & Answers
Turn off the breaker and wait for 5 minutes. the follow these steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Whirlpool... | Answered on Feb 26, 2018
Replace the fuse that relates to theses burners. If nor sure, replace all the fuses. ..noting first where each was taken from. The 30 amps are for the oven; 20 for the elements. 15 for the light.
Whirlpool... | Answered on Oct 21, 2013
Yes it is now extremely dangerous to use this oven. It seems that the extreme heat has warped the panels. This is not usually repairable. I would suggest that this oven be discarded and pictures sent to the manufacture. They may offer you some sort of help in the purchase of a new range. Hope this helps. Good luck.
Whirlpool... | Answered on Nov 18, 2009
same problem that no tones are working on the oven and no sound when timer reaches end of cycle
Whirlpool... | Answered on Nov 14, 2009
sounds as if a wire or part has shorted causing circuit breaker to tripp.
Whirlpool... | Answered on Sep 28, 2009
Google (whirlpool)(gfelvb)(manual) without parens OR contact Whirlpool directly to request it.
Whirlpool... | Answered on Sep 13, 2019
William muller, We would like to inquire further about your post with you. Please respond back to this email address [email protected] with your name, user id (William muller), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Whirlpool... | Answered on Aug 26, 2019
If it works leave it alone. current is a function of voltage and resistance
The igniter current I in amps (A) is equal to the resistor's voltage V in volts (V) divided by the resistance R in ohms (?):
Whirlpool... | Answered on Jul 29, 2019
The F2 E0 error indicates a communication error at the key pad. The key pad could be faulty. There may be a problem with the wiring between the key pad and the control board. The last possible issue is a problem with the oven's electronic control board. First unplug the range (or turn it off at the circuit breaker) and take a look at the wiring. Disconnect and reconnect the wiring harness between the key pad and the control board. Check for any damaged wires in the wiring harness or corrosion where the wiring harness connects (and in the plugs) on both sides. If the wiring is okay, connect the range to power and wait to see if the message recurs. If it does, you'll need to replace the key pad. If the error recurs, then replace the control board when that is sold as a separate assembly.
There is a parts diagram and pricing list for the RF265LXTB1 here: https://www.appliancepartspros.com/parts-for-whirlpool-rf265lxtb1.html . On this range, the replacement key pad and the control board are sold as a single unit. It's part 11 on the Control Panel diagram.
I hope this helps.
Whirlpool... | Answered on Jun 25, 2019
Whirlpool GERC4110PS Kitchen Range Logo
21 questions posted
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Kitchen Ranges
Most Popular Question
kitchen aid kesa907 error f2e0
  • Kitchen Ranges
