My ge washer when i push start the wash light flashes and beeps and wont do anything
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
SOURCE: washer on will not start
Is your inlet pipe to the machine "on"?, is the door firmly shut? Have you overloaded the machine? The inlet pipe is not clogged......
SOURCE: F H beeping
ck fill hoses at rear connection and inside fill valve for debris..also be sure both faucets are fully on and there is sufficent water flow through both to washer be sure drain hose end is 30-36 inches from floor and fits loosely in standpipe ..allck ok then replace flow meter ..remove top on left side small round object with hose in each end 1 end goes to dill valve other to dispenser..flowmeter ckd for water flow into washer
SOURCE: the wash beeps all the time
I had the same problem about a year ago. Out of the blue, the washer would start beeping and blinking. While the washer would run fine, it was annoying. Anyways, I had the service guy in and he had to replace the control board panel (under warranty). Without warranty, the cost of the part would be ~ 150.00. It was fine after that.
SOURCE: END OF CYCLE KEEPS BEEPING WHILE WASHING
Maybe the machine is telling you that your load is uneven, When going through a spin cycle it will detect if the load is too heavy on one side. Just open the door and spread the load evenly. good luck.
