20 Most Recent
GE G.e. Gtwn4950lws He Top Load Washer Questions & Answers
Washer will not high spin
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test: If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test.
WARNING:
This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a bloody death. Proceed at your own risk! Have a nice day. - put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand - turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin - if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand - if it takes very little force to stop the tub from spinning, the clutch needs to be replaced. Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either) Next check for a loose, worn or broken belt if belt driven. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle. On some front load models u may need to check the STATOR assembly. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed. Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand. Your next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer. Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washerhttp://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiNBy the way my advice is free cuz God is good!
5/25/2015 5:36:17 PM •
GE G.e....
Answered
on May 25, 2015
My washer has stopped spinning. Is it a band that is broke or is the motor broken?
could be 8-10 different things. need to know a few more things in order to best guess it. 1. does the washer go through all of the other actions EXCEPT spin? i.e. does it agitate after filling and starting the wash cycle? how old is the machine? were any of the belts previously replaced? have you owned the machine since it was new? what size loads do you wash+how often? where has the machine spent its life? type of climate is determined by state and whether machine is inside house, on screened porch, outside,etc. amount of humidity plays a huge role in life of both machine parts+belts.
4/5/2015 6:31:25 PM •
GE G.e....
Answered
on Apr 05, 2015
Greese spots on laundry from my G.E. washer
need these questions answered 1st in order to address your issue. are the spots black grease as in the type of grease used to lubricate the drum mechanism? also, did you purchase the washer new or used and have you ever had it serviced?
8/25/2014 10:46:51 PM •
GE G.e....
Answered
on Aug 25, 2014
Banging drum when spinning
if the drum in the washer klunks/bangs in ANY brand of washer when it is spinning, your load is off balance. stop the machine, re-distribute the wet clothes so that the weight is evenly distributed, then restar the spin. u may have to do this more than once if u did not evely distribute the weight. this is an easy one. just be sure to stop the spin soon as it starts banging. letting it bang thru an entire spin cycle could result in actual damage to the machine. some of the new machines auto shut off at an imbalance so u can correct the problem. think of spinning a top. u unevenly add weights to it then spin it again, it WILL wobble.
8/2/2014 12:45:01 PM •
GE G.e....
Answered
on Aug 02, 2014
Drum banging when it spins
Two things might be in play. First, the washer needs to be level and on stable surface. Next the laundry needs to be fairly evenly distributed in the tub. I have had this happen, and sometimes it just needs releveling, particularly if you had a heavy unbalanced load.
8/2/2014 12:44:16 PM •
GE G.e....
Answered
on Aug 02, 2014
