I have two TV's both hooked up to Satlink 4000 Digital Satellite Receivers and connected to a Sky dish Please advise how I can regain the Prime channel on 23 and how I can get Stratos on 16
SOURCE: toshiba 36a41 television
You should be able to use your remote control to do this.Your channel 73 is more than likely UHF 73 so you need to put your tv in the antenna setting rather than cable setting. Once you do this just input 73 with your remote. Hope this helps! Stargazer
SOURCE: plasma tv connections
Hi ,,
Ok First off your Plasma has 3 inputs , 1 ,2,3
Here is what i would have done and what you can do.
First of your recivers has RCA output, thats 1 yellow cable and 1 red and 1 white,
The red and white are audoi and the yellow is video
1.) Connect your dvd player to input 1 in your Plasma.
just follow the color codes, yellow to yellow, white to whit, red to red,
2.) connect the other Reciver to input 2
using the same method
3.) connect the dvd to input 3
using the same method..
So now if you want to view reciver1 you set the tv to input1, reciver 2, input2 , dvd , input 3
In the event that your tv does not have 3 seperate inputs
you can go to your locol electctronics stor and purchase an RCA switch box
this is a device that has 3 seperate RCA inputs, a switch to slect which one you want to use and an output to connect to the tv, Simply connect all your devices to the RCA switch, and then connect the rca switch to your tv..
There are other methods of doing the same thing, but i chose this one as its the most simple solution
let me know if you are having any problems
SOURCE: - SKY REMOTE CODES
I own a One-for-All universal remote (model URC-4220), and my booklet says the setup code for a Hitachi TV is either 0000 or 0145. If these numbers do not work, then I would buy a newer universal remote. They can purchased at Walmart for less than 10 dollars.
SOURCE: Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
SOURCE: RCA Colortrak 2000 remote control
I called RCA's 800 number on the back of the owner manual--got a response that said to replace the unit since only the up-down channel changer buttons were not working. Using another remote (universal) now--cost only $5.
