Every thing works but I can't get the door to open so I can put my cd in . I can hear the clicking sound but the door will not open
Loading mechanism fault. Check the loading belt. If it is broken, CD won't eject, or load well inside the mechanism. If loading motor is damaged, this kind of fault can occur. Anyway, you have to take out the mechanism out of it to get it repaired. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
SOURCE: will not record
the classic cdr201 will not record it will go to wait and return to cd status(blank cd etc) there is no led display of sound during this operation you can hear the audio for brief couple of seconds before it goes back to cd mode
SOURCE: sony cdp-c545 won't open
Without turning the unit upside down, look at the bottom of the player. You should see a small round hole toward the front of the unit, with a white plastic part inside with a slot. Take a screwdriver and turn this gear manually with the power off. You should be able to unload the discs by rotating this gear. Be careful not to tilt the unit, as the discs will fall out of the tray, and you'll have to open it to retrieve them.
Once you have the discs out, put in only one disc and see if the unit plays. If you get a disc error, you probably need to clean the lens on the laser. Open the unit, use a cotton swab that has been pre-wetted with glass cleaner to wipe the lens on the laser. Do this gently, don't press down hard on the lens. Use the other end of the swab to dry the lens. Try loading a disc with the top cover off and see if it spins. If it doesn't spin, try turning it by hand. If you can't turn it by hand, the gears have gotten out of alignment.
In this case, use your screwdriver again, noting which way the gear on the bottom of the unit spins when the drawer is going into the unit. Then turn the gear until it "pops" past one or two teeth, and then you should see the laser assembly rise up and meet the clamp assembly on the top of the tray. These are the most common problems with the 5 disc players that Sony made. Many times I could fix them in 30 seconds or less using this procedure.
SOURCE: Discs stuck inside CD Player. Screen says ''Reading.''
Try resetting the CD (Cambridge soundworks) by unplugging, then repluging. Then hold down the eject button while you turn on the power.
SOURCE: cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
