I have a pretty old but great-sounding cd player that has a cassette deck in it and a radio. It is powering up fine and the cassette and radio work. The cd part is showing me the message DOOR OPEN whether the door is open or closed. I am not able to play cds due to the fact that the machine thinks the door is always open. Any ideas, please? :-)
SOURCE: CD Player display always show "Open"
Theres a protruding plastic that pushes the close detection switch inside, the switch might have gotten dirty or reshaped, you can remedy this by adding height to the protruding plastic, or have someone disassemble the unit for you. It can easily be remedied by a technician...
SOURCE: Intermittent Power Problem when playing CDs
Hello db1964,
I have a cdf-e75 that had a similar problem, although the red power light was dim for all functions. (the radio, tape and cd)
After opening up the unit and inspecting, I found one of the pins on the printed circuit board for the power had broken away from the solder. (it is a tiny board where the AC connector is soldered to) Seems in my unit there is nothing securing the molded AC connecter to the plastic case except the the printed circuit board it is soldered to-It is a poor design; perhaps your is the same? I suspect over time pushing the AC cord into the back of the player may have broke the connection? Anyway, I soldered the connection and I have never had any additional problems as the unit has worked fine since.
Don't know if this helps, but my suggestion would be to open the unit and inspect the pin connections on the AC printed circuit board to see if any have a loose/broken connection. ( Mine was not noticible with the naked eye as I had to use a magnifying lens and a bright light. Hope this might help.
SOURCE: Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
SOURCE: Freak Out!!!
Correct on the ribbon cable but parts can be ordered for it, duel has service centers, inc the one i work @. its abought a $10 part
SOURCE: Sony Stereo Cassette Deck TC-WR550Z
Drives belt has become too slack to drive mechanism properly or the drive motor is bad. Have unit serviced for new belt(s)
