The bell symbol has a line through it, and the handset doesn't ring, so I'm missing calls if I am away from the base. I turned it off accidentally, I've read the manual, but can find nothing to resolve the problem. How do I turn it on again. I do not need to alter the volume, just get the handset to ring so I can hear it
SOURCE: How does one get the handsets to record the new speed dial numbers on the base phone?
I'm pretty sure the speed dial numbers are programmed on a per-phone basis. Most people would not want changes on one phone's speed dial to effect the other phones. I know registering the handsets will not make a difference. If the cordless phone is working, it's registered to the base. This is required so your neighbor cannot buy the same phone model and use your phone line. In the old days cordless phones were permanently linked to one base but now you can get extra handsets on many systems and "register" the phone to work on your base.
SOURCE: ELBT595 Handset Not Turning On
Check the handset battery -- if there is a slight "bulge" on one side (ie: not COMPLETELY flat) then the problem is with the battery. I had that problem and had to order a new one. That said, I just installed the new battery, and while it now charges, the handset won't connect to the base unit. The base unit works (tried the speakerphone), but there is not connection between base and handset.
SOURCE: Handset Won't Connect to Base Station
OK sorry guess I was thinking you had 2 handsets.
My suggestion is go to the Uniden website and maybe see what they have there.
Maybe do a search on the Uniden site for that Automatic Digital Security Code thing, seems it would be easy to fix, just a matter of how....
In the meantime I'll do some searching and see if I can help and find a fix
SOURCE: I have the DECT 6.0 and My hand set wont ring
Ringer may be muted (turned off).
If you need a manual to check correct procedure, here is a link.
http://www.uniden.com/index/manuals_results.cfm?cat=59
Select model and download manual.
Hope it helps.
SOURCE: i have an Uniden power max 5.8 GHz home phone but
Sounds like the handset needs to be re-associated with the base unit.
If the manual for the Uniden PowerMax manual on the FixYa website for manuals is not the correct manual, go to the Uniden website and locate the manual there.
