Go to youtube ,type in the model of your camera, and see if your camera comes out. i did a video on a repair years ago, but not sure if its still up, or part of the repair is still up. i purchase a used part (ribbon) that was torn, off a used camera off ebay
If you need help with your sony hdr-xr150 here is a service manual for it:
http://goo.gl/9JXNiG
thanks
SOURCE: sony hdr-fx1 lcd problem
We have this HDR-FX1 LCD Screen in stock. For further information pl. email me.
Best Regards,
Sharmila.
SOURCE: the lcd screen is almost black/ very dark, but i
The LCD screen may be turned OFF. To turn the LCD backlight off or on, press and hold the DISPLAY/BATT INFO button for a few seconds. After the backlight has turned off or on, release the button.
SOURCE: LCD on Sony HDR HC1 not working
This happens when flexible wire between LCD board and camcorder board got broken or cracked.
Camcorder needs that connecting flexible wire replacement, let me know exact model of Sony camcorder if you need part number of flexible wire.
Thanks.
SOURCE: Sony HDR-HC3 LCD touchscreen blacked-out.
I have the same problem, screen went red then about a month later went black. If I rotate the screen so its on the outside when flat against the camcorder side, it works OK so I'm living with that for now, but you can't use the corder in the normal way for recording viewing the screen. All other functions are OK.
I have the problem, but not the solution.
Rob
SOURCE: have E:61:10 flashing up on screen. cannot find it
error code alerts user for malfunctions detected by the camera. the error E:61:10 would pertain to the zoom mechanism malfunction. issue may be with with lens block zoom MR sensor or zoom motor drive circuit. 1st step troubleshooting steps would be to reset camcorder (check manual for reset button location) and power reset (remove battery and leave camcorder w/o any power source for a minute). if still the same then service would be required. hope this info helps. thanks.
