Part:
Sony SR11 SR11E SR12 SR12E XR500 LCD flex cable
Example & service manual:
Sony HDR SR11 HDR SR12 Repair
SOURCE: distorted picture when looking through view finder or lcd screen
the video playback is sampled off the video out and independently processed sorta like a TV signal to project on the lcd screen.
horizontal lines means you lost sync circuit and needs troubleshooting. Hopefully maybe a bad connection with a ribbon cable for the ICs and components are hard to change and jammed tight. I would order a video board.
SOURCE: I have a Sony HDR-SR11 and the time/date stamp is
I believe that you can select the DISP button on the left side of the camera to make the date and time display disappear from the viewscreen on the camera. I do not know if this will remove it from the footage that you will need to download to your PC or DVD. If you have downloaded it already you may need to select the DISP (for display) button and then re-download the movie footage.
SOURCE: no picture when recording have sound just lines going through len
Seems ccd imager is bad in your Sony camcorder that you get noisy picture in recording. Let me know exact model number of camcorder to provide you more info.
SOURCE: the lcd screen is almost black/ very dark, but i
The LCD screen may be turned OFF. To turn the LCD backlight off or on, press and hold the DISPLAY/BATT INFO button for a few seconds. After the backlight has turned off or on, release the button.
SOURCE: Sony HDR-SR11 HDD camcorder does not connect to my pc.
you can tried using the firewire cable
