Pioneer AVH-P5700DVD Car DVD Player Logo
Posted on Jun 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I align the touchscreen ?It is off to the right and i can't operate it properly cause i can't touch every button on screen
Anonymous
Level 2:
  • Expert 365 Answers
  • Posted on Jun 14, 2009
Anonymous
Expert
Level 2:
Answers
365
Questions
0
Helped
156969
Points
951
Take an air "lance" from an air compressor and using LOW - GENTLE pressure blow the entire perimeter of the screen...Good Luck
The touch screen doesn't work with my finger tip, only when my nail touchs screen, also did the screen calibration, did not not help
It may be a resistive screen rather than a capacitive screen which is not as sesitive to touch. You may need to use a stylus as it may need slight pressure vs just touch if it is a resistive screen.
My v touch pro touch screen wont work
b> The Touch Pro2, manufactured by HTC, is a smartphone designed to be used with the Verizon wireless phone network. This smartphone combines a cell phone, PDA, MP3 player and wireless Internet access into a small, portable device. If the device begins malfunctioning or freezing, you can perform a soft reset. A soft reset does not delete any of your saved information. It shuts the phone down and reboots the phone to the Verizon Today Welcome Screen.
Pull the stylus upward to remove it from the side of the phone. Push the back cover upward using your thumbs until it pops from the back of the Touch Pro2 phone. The back cover can then be lifted away and removed from the phone. Press the "Reset" button, on the upper, left side of the back panel using the stylus tip. The device will now restart and display the Verizon Today screen. Snap the back cover back onto the back of the phone. Touch Screen is Not Working
As most tablet PCs ,Phones and Mp3 players are full touchscreen devices, you use your touchscreen for everything you need to do on your Tablet PC. If the touchscreen stops working, you can't get much use out of your Tablet. Touchscreen issues are caused by hardware or software problems, but check with your manufacturer before attempting a DIY repair.
Hardware Issues Damages to the surface of your Tablet PC can cause the touchscreen to malfunction or stop working entirely. For example, putting pressure on the screen, such as placing the Tablet PC in a bag with other heavy items, can cause cracking along the screen. Exposing the screen to water, even in small amounts, can cause the electrical system within the touchscreen to malfunction. If the electrical system malfunctions, the touchscreen stops working properly. b> Screen Sensitivity b> Pressing the touchscreen on your Tablet PC sends a signal to the internal motherboard. The motherboard then transmits to other components, such as the hard drive. The accuracy of the touchscreen depends on the screen's sensitivity. Many Tablet PCs include a program for calibrating the touchscreen. This program may fix minor responsive issues. Even a small amount of dirt or debris can effect how the touchscreen responds. Cleaning your touchscreen with an electronics cleaner or a microfiber cloth may help improve sensitivity. b> Software Issues b> A driver is a software program that interacts between hardware devices and an operating system, Your Tablet PC needs the right drivers for your OS to work correctly. Outdated or missing drivers can cause the touchscreen to work improperly, or not respond at all. Visit the manufacturer's website to find the right drivers for your Tablet PC. b> Repair b> While you can perform some minor repairs yourself, such as re-calibrating the touchscreen sensitivity or installing drivers, only perform a hardware repair if you have a good working knowledge of electronics, specifically Tablet PCs. Before attempting to repair your device, contact your manufacturer. If your Tablet PC has a warranty, completing an unauthorized repair may make you ineligible for claiming that warranty. Hope this helps
b>
Touch screen do not work when touch on any icon
Your might need touchscreen configuration. Please follow the below solution.
If you are asking about the touchscreen of your desktop PC then I would suggest you go to control panel and look for ELO Control Panel where-in you will be guided to touch three targets on the screen. Then Verify the touchscreen if it is working and aligned properly. If you need to align further then go back to the ELO control panel and repeat the process.
My touch screen is off the mark
My touch screen does not operate properly. When I attempt to press/touch a character another character appears. Example when touching 1, 4 apperars on the screen. How can I correct or reset the touch...
The touchscreen portion of your display is severely out of alignment. Try finding the utility(use hardware keys) to align the display (under settings). Try to align it. If it is too far out of range, it will kick out your "presses". If this happens, you *might* be able to try a reset, but it likely will not work. Otherwise, your only recourse will be replacement or repair.
1helpful
My p1i pen calibration or the touch screen is not working properly,,...for example when i touched the menu button from the screen i have to touch it further up from the actual place of the button is...
if your alignment utility does'nt help. it sounds like touchscreen is bad, check this out on EBAY
Item number: 390075800894 Item location: Brooklyn,NY, United States Ships to: N. and S. America, Europe, Asia, Australia Payments: PayPal See details History: 18 sold
2helpful
2answers
Iphone touch screen is not working. Restored the phone from backup succesfully, but screen still doesn't work. Phone receives calls, etc., but can't unlock or answer calls because screen doesn't respond to...
Even though the iPhonemag-glass_10x10.gif is a device that is extremely convenient to have, it still can cause frustrations. Specifically, there may be times when the touch screen does not work properly.
There are various problems the iPhone touch screen could encounter. Although there are times when the screen does not work altogether, there are other situations when certain portions of the screen work and others don't. Of course, it is possible that the entire screen works, but is simply slow. Regardless of the exact problem, there are ways to troubleshoot the iPhone to diagnose the real problem.
  1. tep 1 Remove the wiping cloth that came in the small black envelope along with the iPhone. Wipe the smudges or dust off the screen with this cloth. It is best to wipe in a circular motion.
  2. Step 2 Do not put lotion on your hands and do not touch the screen if your hands are wet. Any kind of moisture can affect the way the touchscreen operates. Moisture sometimes slows the response time from the screen to the operating systemmag-glass_10x10.gif.
  3. Step 3 Check for a protective sheet on the screen. If there is some kind of a film or sheet on the touchscreen, the screen is likely not able to react to all of the sensitivities of the touch of a finger as it normally would.
  4. Step 4 If there is an application open and the touchscreen seems to not be working, simply close the application and retry it. A frozen application can usually be closed by pressing and holding on the circular button located just below the touchscreen.
  5. Step 5 Press and hold the home button as well as the reset button on the top of the phone to turn the iPhone off. A red slider will appear. Slide it to the right to turn the phone off. Press again on the "Reset" button on the top to turn the phone back on.
  6. Step 6 Completely reset the iPhone by holding the "Home" button and the "Reset" button for a full 10 seconds until the phone resets and the Apple logo appears on the phone.
    • If you are using the iPhone in cold weather and wearing gloves, the iPhone will not react to the gloves as it will to the touch of a finger.
    • If the touchscreen is dirty, do not run the iPhone under water. Doing this will likely ruin the phone, but even if it doesn't, it will possibly make the phone run slower.
2helpful
3answers
Htc touch, touch screen not working
The touchscreen is a thinlike mylar sheet that overlays the screen. Once damaged, all you can do it get it replaced. To verify if the touchscreen is "smashed", try using the thumbwheel or up and down buttons. If you can move around the display, then this means the touchscreen is damaged but will not prevent you from using your device, that is, until you turn it in for repair/replacement.
2answers
Samsung sch-i730 touchscreen problem
use buttons to go to start,settings,system,screen then click align screen
2helpful
Screen Alignment of Motorola E6 not responding at Bottom right
there's two possibility, which for ur case i suppose, a simple format will help. Format ur phone (soft format goes with -- factory setting) which i remind you, it will erase all your data, back up ur datas to computer first or to ur memory card, and ur phone book to simcard or to pc, anywhere u want. the hard format-- u must go to technician after the soft format fail.
if the two format doesn't help at all, that means ur touchscreen surface is having problem, bring it to technician to get it fixed.
hope u get lucky by just formating - cost u nothing.Gud luck
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
