20 Most Recent Samsung SCH-i730 Pocket PC Questions & Answers
Green:Fully charged
Amber:Improper connection
Red:Charging
Samsung SCH-i730... | Answered on Aug 30, 2012
pls how do i align my screen with ease?
Samsung SCH-i730... | Answered on Mar 05, 2011
Hello.
Try resetting the phone by pressing in the tiny hole on the bottom of your phone with an opened paper clip.
Hope this helps.
Samsung SCH-i730... | Answered on Nov 11, 2010
if ur fone is wifi compatible its free
Samsung SCH-i730... | Answered on Apr 12, 2010
Try this code but back up you files before doing this.*#2767*3855,and wait until the phone restart completely.If still asking a code put or type this 00000000.
Samsung SCH-i730... | Answered on Mar 15, 2010
لايظهر شعار ويندوز
Samsung SCH-i730... | Answered on Feb 17, 2010
Hi if your phone is unusable and you can't do anything with it, then the only solution there is, is to do a hard reset: A hard reset is the last resort for troubleshooting. This reset will erase all data and restore preferences to factory default specifications. Slide down and hold the Power button (located on the left edge, near the base of the device). While continuing to hold the Power button, insert the stylus into the pin-hole (on the bottom edge of the device near the left side) to press and hold the Reset button. After approximately 5 seconds, release the Power button and stylus from the Reset button. When the reset is complete, the Windows Mobile splash screen will appear with the prompt Tap the screen to set up your Pocket PC. Note: The procedure to hard reset the i730 has changed in the Windows Mobile 5 version (only). The new procedure is: 1. Press and hold down the top left menu button while pressing the slider down. 2. While performing the above, press the reset button located on the bottom left of the phone. You will see a message "Formatting Root" let the process run without disturbing the phone. It is a little tricky performing all three at once but it works.
Samsung SCH-i730... | Answered on Oct 31, 2009
yessssssss GET A NEW FUCKINGG PHONE!!!!!!!!
Samsung SCH-i730... | Answered on Oct 22, 2009
Try sliding the phone open and dialing out that way, if it asks if you want to turn the phone on tap yes and make your call and see what happens.
Samsung SCH-i730... | Answered on Oct 08, 2009
Yes, once you turn the wifi on it should disable the phone anyways, which sends all internet communication onto your home wifi (Internet you pay for via dsl or cable)not the phone providers.
the contacts on the card or phone might be dirty or the sd might de formatted in a format that the phone wont reconize
thats whats happening to mine right now and i can't figure out how to get it to turn back on!!
Samsung SCH-i730... | Answered on Sep 22, 2009
so you lost the stylus i would suggest finding a replacement one because that is kind of important however there are many blue tooth devices that require a stylus and you can get pen stylus combo sets.  To do a master reset on the i730 you are going to hold down the power button slider place the stylus in the rest hole on the bottom of the phone then hold for five to ten seconds and release the power slider and then remove the stylus from the reset button.  This should work and the phone is very particular about order and timing.  You might have to try it several different times but this should work for you=)
Samsung SCH-i730... | Answered on Sep 21, 2009
Simple. It has a Search WAN option in Connections. Select that. and automatically it will search all WiFis around the house. Select the one that is yours and enter the WEP key when asked for. You are now on the net.
Samsung SCH-i730... | Answered on Aug 23, 2009
k..
Thankyou
Appreciate a good rating from you..
Samsung SCH-i730... | Answered on Jul 31, 2009
Samsung SCH-i730 Pocket PC Logo
59 questions posted
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Computers & Internet
Most Popular Question
samsung i730 mits lock code
  • Computers & Internet
