1996 Chevrolet Blazer Logo
TaLi LaMont Posted on Mar 10, 2014
Why does the car stall in my 1996 s10 chevy blazer while running?
When I start my car up, or even while I am driving, the car tends to stall, then the battery light comes on, what is the problem?
Keene
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 14, 2014
Keene
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
1182
Points
5
A car stalls when the engine receives a sudden massive increase in load (think when you were learning to drive - releasing the clutch too quickly would cause the car to stall by transferring too much friction too quickly from the gearbox to the engine)
If the car only stalls when you are setting out from stationary then better engine/clutch control control is needed, or there is a problem with fuel or clutch. If it is an old car, try putting more choke on when pulling away.
If the car stalls all the time, the general reason is that there is probably either a fuel or an ignition problem causing the engine to cut out. Of course, there could be any number of things wrong with your car if it stalls during normal driving
3 Related Answers
Anonymous
  • 56 Answers
  • Posted on Nov 25, 2008
SOURCE: 98 chevy s10 blazer turn signal
Unplug the turn signal relay from the fuse box and start you engine. Does it still make that noise?
If yes... Put the relay back in, that is not the problem.
If No...Then the relay could be bad, replace it!
PLEASE RATE THIS SOLUTION! Thank You Very Much!
dennymulford
Dennis Mulford
  • 1055 Answers
  • Posted on Jan 24, 2009
SOURCE: 91 s10 blazer engine surges warm and cold, stalls
tps sencor or maf sencor
Anonymous
  • 10319 Answers
  • Posted on Sep 28, 2011
SOURCE: 1993 Chevy S10 Blazer transmission problem...
the trans is electronic so the PCM is at fault
Will a 1996 4.3L from a Chevy S10 blazer fit in a 2001 Chevy S10 blazer? Both have 4 wheel drive
it will bolt up but your problem is all the electronics and sensors dont match up
2answers
My 1996 Chevy S10 Blazer
Sandra, You probably will not get code from computer as it may not be hooked up to an engine running a carburetor in a 1996 Blazer. Carbureted engines were not installed in 1996 Blazers. Could be a lot of things, choke sticking/faulty,dirty carb, not set properly, bad plugs/wires, fuel filter/pump, faulty distributor/cap/rotor/electronics,vacuum leak,etc.
Best to have a good tech. have a look and estimate repair.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Diagnose and Repair Carburetor Problems
http://www.thecarburetorshop.com/Troubleshooting.htm
http://www.championparts.com/carb_troubleshooting_guide.pdf
Schematic for 1996 chevy blazer fuel tank
Get a Haynes or Chiltons Manual for diagrams and instructions for your vehicle.
2answers
1993 chevy s10 2.8 v6 crank sensor?
I don't think they have a crank shaft position se 2.8 m Nleader
1996 chevy blazer starts and then stops
Its either the fuel pump or the fuel regulator.Fuel pressure sure be 60-66 psi with key on and engine off.
I have a 95 S10 Blazer- vehicle code W (DI). The car starts fine but immediately wants to stall. If you press the accelerator you can keep it running and it runs down the road just fine until you slow to...
no its not the crank sensor if it were your car would not even start. your problem most likely is the idle air control valve, try removing it and and cleaning it if it does not help it will have to be replaced.
My 1991 chevy s-10
when i start my 91 s10 blazer it try to stall so i have to give it gas to keep it running then when i leave out of the drive way and go down the road it has problem get the right amountof gas to go but once it hit 60 -70 mile an hour its fine
My 1996 Chevy Blazer will not start.
It is inside the channel of the frame rail under and to the rear of the drivers door.
1996 Chevy S10 stalls out 3 times before steady start
check for loose or cracked vacuum lines, and/or the rotor. It may not be making consistant contact.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
